Rims questions?
Rims questions?
Will rims from a 2nd generation GS fit on the 3rd generation GS? The setup are 20 x 8.5 w/ 38mm offset in the front and 20 x 9.5 w/ 35mm offset in the rear. Tires size is 245-35-20 in the front and 275-30-20 in the rear.
That's a toss-up... you might be ok, but I'm not 100%.. I believe you still wil have to. When you lower the car, You usually get some negative camber which in turn gives you a little more clearance...
The One
Originally Posted by Eternity3G
No problem. The rear is a little on the strong side, but it works. Get ready to chop some fenders though!
Originally Posted by Neo
9.5 +35 is right on the border for the 2GS. Depending on a few more factors (alignment/camber, tire choice, lowering), fender work may or may not be needed. For some reason, I thought the 3GS had a little bit more room. With you owning a 3GS and your wheel experiments, I guyess you'd know better than me David.
also.. like you said NEO, Depending on a few more factors (alignment/camber, tire choice, lowering)
Juss2 G
02-22-06 10:09 PM
