question about running mismatched pairs of tires?
Old 04-27-06, 08:31 PM
Benjamin T
Benjamin T's Avatar
Default question about running mismatched pairs of tires?
a fellow listmember is selling a set of wheels and tires with 245/35/20 falken ST115's in the front, and 275/35/20 falken FK451's in the rear. the reason it's like this is because you cannot get ether tire in the other size... ie. the ST115 dosen't come in a 275, and vice versa with the FK451.
the wheels are very expensive, and it would be awhile before i could afford new tires... will running this sort of setup cause any issues i should be aware of?
this is meant for a 99 gs400... thanks in advance.
Old 04-27-06, 10:31 PM
rominl
exclusive matchup
rominl's Avatar
i ran different tires front and back before, for normal driving it's no problem. but if you take your car out hard, that could pose quite a bit of problem coz' of different tractions
Old 04-28-06, 07:59 AM
Benjamin T
Benjamin T's Avatar
will running a supra LSD be an problem?
Old 04-28-06, 08:58 AM
rominl
exclusive matchup
rominl's Avatar
mainly it still has to do with how you drive (aggressively or not)
Old 04-28-06, 09:31 AM
Benjamin T
Benjamin T's Avatar
right now i have an understeer problem. my gs has a trd blue swaybar in the front, but a stock one in the rear (not sure why the previous owner did that). if i didn't keep it slow it would plow right through a corner. now with the LSD, it will try to snap oversteer when i give it throttle.
siksc16
07-14-13 06:01 PM
DS2k
IS F (2008-2014)
04-10-12 01:22 PM
is2fiddy
04-19-10 07:59 PM
twitch
07-06-07 05:56 AM
mjr24
02-08-06 09:04 AM
Quick Reply: question about running mismatched pairs of tires?
