is running 235/35/19 and 265/30/19 safe on a GS?
Old 04-26-06, 11:16 PM
ShaneC
ShaneC's Avatar
Default is running 235/35/19 and 265/30/19 safe on a GS?
i just want to double check if these tire size will be ok. i know 235/35/19 and 275/30/19 are a closer fit and may people are running that set up. but if you run 265 rear with the same 235 front, will that be bad??
Stock 225/55/16
radius: 12.9 in
Diameter: 25.7 in
Circumf: 80.9 in
Revs/Mi: 793.0
Fronts: 235/35/19
radius: 12.7 in
Diameter: 25.5 in
Circumf: 80.0
Revs/Mi: 792.0
Rear: 265/30/19
radius: 12.6 in
Diameter: 25.3 in
Circumf: 79.4 in
Revs/Mi: 798.0
Rear: 275/30/19
radius: 12.7 in
Diameter: 25.5 in
Circumf: 80.1 in
Revs/Mi: 791.0
tire Calculator
i wanted to know if having the rear rotate 6 times (265/35/19) more then the front wheels per mile be bad for the car in the long run? (i remember i read before GS need to have the same diameter wheels in the front and rear) i mainly want to know how much of a difference can there be before you start getting into trouble?
Thanks guys.
Old 04-27-06, 12:16 AM
Neo
The One
Neo's Avatar
Although not as optimal. they should be fine. They are pretty close. Just curious. Why are you running 265s?
Old 04-27-06, 11:27 AM
ShaneC
ShaneC's Avatar
i am buying used rims with tires.
Old 04-27-06, 10:29 PM
rominl
exclusive matchup
rominl's Avatar
if you drive careful, they are ok. of course not as optimal like neo said
kaizen8
07-19-14 08:33 AM
LexusISF19
IS F (2008-2014)
13
05-28-14 07:15 PM
eliteskill
SC- 1st Gen (1992-2000)
29
03-24-10 02:44 PM
NORCAL SS
Suspension and Brakes
05-09-07 08:48 PM
bLingIn3o0
02-11-04 08:54 PM
Quick Reply: is running 235/35/19 and 265/30/19 safe on a GS?
