LS400 Help!!!!!!!!!!!! ASAP
I have four 255/35/20 tires with +35 offset rims. I wanted to know if they will fit on a 96 LS400 without having and rubbing issues and fender rolling.
thank you
thank you
you can rub with any rim with any tire at any height, as each car is slightly inherently different.
in any event, assuming the bolt pattern is correct, the width of the rim in addition to the offset you've inlcuded is important in determining whether or not there will be major rubbing issues or not.
Originally Posted by absolut
fatlouis
11-30-15 06:38 AM
SharkMark
06-06-13 06:15 PM
