spacers for aftermarket wheels for IS350
Old 04-13-06, 05:20 AM
Lexo350
Lexo350's Avatar
Question spacers for aftermarket wheels for IS350
for those of you that did a 19" or 20" wheel did you have to put spacers for the front wheel like a 1/8" spacer so that the wheel would fit? I was told that I would have to put spacers for most wheels because of the huge calipers. can any one help.
Old 04-13-06, 05:40 AM
4TehNguyen
4TehNguyen's Avatar
if you see the sticky aftermarket wheel thread i dont see an instance of anyone using spacers
Old 04-13-06, 08:45 AM
federalman
federalman's Avatar
if the wheel have the correct offset you do not need a spacer.
Spacer is only need if you want to push the wheel out a bit or try to fit a wheel with wrong offset on your car.
Old 04-14-06, 08:11 PM
Dj Rando
Dj Rando's Avatar
I had that problem too. Found the right tire shop and was able to get the right wheel. I have 20's staggered and love them. No spacers.
Old 04-15-06, 12:25 AM
rominl
exclusive matchup
rominl's Avatar
guys.... offset is not the problem. in fact it has little to do with brake calipers clearance. disk type is the biggest problem here. when you get wheels for is350 or cars with bbk, you need wheels that's HIGH DISK in the front, so the spoke design curves out more to clear the brakes. and then the offset might help a bit and give the final touch.
imho using spacers to clear the calipers that's not the right thing to do
Old 04-15-06, 03:09 AM
t0e
t0e's Avatar
Lightbulb i would like to know
It would be nice to know if there are currently some available.
Old 04-15-06, 02:15 PM
rominl
exclusive matchup
rominl's Avatar
what available?
Old 04-17-06, 02:01 AM
t0e
t0e's Avatar
Originally Posted by rominl
what available?
Spacers for the is350, i would like to push the back wheel out a little more.
Old 04-17-06, 09:04 AM
rominl
exclusive matchup
rominl's Avatar
spacers and adaptors are unversal products, 5mm, 10mm, 15mm, 20mm, 25mm, etc... there is no model specific types. you just need the right bore and pattern. for lexus the bore is 60.1mm and pattern is 5x114.3. that's all the info you need
west709
04-04-13 09:08 PM
chanho083
06-25-11 09:35 PM
Codfish
Suspension and Brakes
11-07-10 01:50 AM
lexi4darin
08-28-07 08:37 AM
Daddy-O
RX - 1st Gen (1999-2003)
10-19-02 04:38 PM
Quick Reply: spacers for aftermarket wheels for IS350
