99 GS tire set-up 245/30/20 front & 255/35/20 rear
Old 04-10-06, 02:47 PM
neillexx
neillexx's Avatar
Default 99 GS tire set-up 245/30/20 front & 255/35/20 rear
Need some input. I had four 20x8.5 rims with tires on 255/35/20. Two of my tires had a flat and now i need to buy new tires. I was wondering if this set-up would be ok for my 99GS400
Front 245/30/20
Rear 255/35/20
The front tires used to rub and that is why im wanting to change its tire size, as well i would want the front to look lower. What do you guys think?
Thank you
Old 04-10-06, 02:53 PM
neillexx
neillexx's Avatar
Default 99GS400 Tire set up Question? need help asap.
Front 245/30/20
Rear 255/35/20
Thank you
Old 04-10-06, 03:23 PM
AZDesertGS
AZDesertGS's Avatar
It will work but I dont know why you would want to do this. The rears will be about 1.25" bigger diameter.....you won't be able to rotate......and persally won't look right. Go with the same size all around unless you go the staggered route. Good luck
Old 04-10-06, 03:32 PM
neillexx
neillexx's Avatar
thanks for the reply, but i find that when i had the 255/35/20 the front tires would rub constantly.
Old 04-10-06, 09:26 PM
neillexx
neillexx's Avatar
bump....................................................
Old 04-10-06, 10:26 PM
rominl
exclusive matchup
rominl's Avatar
personally i would just do the same size tires all around, since your wheels are same width front and back.
AlexW
03-28-17 09:41 PM
Languistic
05-23-12 10:37 AM
gekae24
03-26-12 12:35 AM
Charlie088
02-21-12 02:17 PM
02Ku
04-06-06 08:42 AM
Quick Reply: 99 GS tire set-up 245/30/20 front & 255/35/20 rear
