Need Help on size of wheels ASAP!
Old 03-30-06, 10:26 AM
vikm
vikm's Avatar
Default Need Help on size of wheels ASAP!
I have a 98 Gs4, and I'm looking at some wheels to buy, hopefully today. I need help on if they will fit properly on my GS. I read Rominl's fitment guide and they might not work.
I do not want to roll or shave the fendor at ALL.
Here is the size I am looking at:
19x8.5 offset 35 Tires 245/35/19
19x9.5 offset 35 Tires 275/30/19
Please let me know if these will work. Again I want a conservative set-up and don't know if these will work
Old 03-30-06, 03:17 PM
vikm
vikm's Avatar
Default anyone????
Wheel expert gurus please help.
Old 03-30-06, 11:57 PM
rominl
exclusive matchup
rominl's Avatar
the front will fit pretty nice
the rear you need to shave the fender tab a bit
Old 03-31-06, 02:58 PM
vikm
vikm's Avatar
Default Thanks Rominl
Thanks again Rominl, I just put a deposit down on some wheels today. You mentioned that the front will fit fine with the 19x8.5 +35 offset. Just to confirm I will not have to do any fendor modification on the front correct?
The back I ended up getting 19x9.5 +40 offset, that seems to be a better fit than the +35 offset.
Thanks again!
Old 03-31-06, 03:15 PM
AZDesertGS
AZDesertGS's Avatar
WHat wheels are you getting??? (also imo...I would get 235 for the front....same diameter as 275 rears
Old 03-31-06, 04:09 PM
vikm
vikm's Avatar
Default Hey AZDesertGS
There Jaz wheels called Trinity with the black face.
I'm nervous about the offset, in the front, seems close but Rominl said that they should work, just need confirm this because I don't want to do any fendor mods. I also will be lowerning the car.
Maybe if I go with 235/35 might solve this issue with rubbing, but I would rather get the wider tires if I can.
Old 04-03-06, 01:53 AM
rominl
exclusive matchup
rominl's Avatar
the front, yes, as long as you use 235 or 245 i don't think you will have a problem. should be good to go
for the back, if you use 275 i am pretty sure you are good with the +40
RC5
RC F (2015-present)
23
04-19-19 05:24 AM
grootds17
CT 200h Model (2011-2017)
10-12-17 07:29 PM
RobzKar
06-22-08 04:32 AM
vikm
03-22-06 08:49 AM
is300plp
Suspension and Brakes
09-24-04 07:08 PM
Quick Reply: Need Help on size of wheels ASAP!
