Will these fit on my gs?
ebay link: http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
UP FOR AUCTION IS A BEAUTIFUL SET OF LOWENHART 20" CHROME RIMS AND TIRES. THESE ARE FOR REAR WHEEL DRIVE VEHICLES ONLY. THESE CAME OFF OF A 2005 MASERATI QUATROPORTE, BUT WILL FIT OTHER VEHICLES. LUG BOLTS WILL BE INCLUDED. DIMENSIONS: FRONT ARE 20X9 ,40MM. OFFSET WITH NITTO EXTREME TIRES 245-35/ZR20 MOUNTED ON THEM REAR ARE 20X10 ,44MM OFFSET WITH NITTO EXTREME TIRES 275/30/ZR20 MOUNTED ON THEM ALL TIRES HAVE 10/32 TREAD DEPTH. THE BOLT PATTERN IS 5X4.5 THESE WHEELS AND TIRES SELL FOR OVER $6000.00 REALLY GREAT DEAL
The bolt pattern is correct.
The offsets will work, but you should do some research on that.
This Link shows that the offset and width of the rear is pretty aggressive. You'll probably be looking at rolling your fenders at a minimum.
I'd ask for better hi res pics of those rims. The two that show damage are concerning. The one that shows a chnk of rubber missing is really concerning. Thats a lot of coin to throw down for something that may need work. Also, his shipping is pretty incredible. To my house it was $398.
I have the same wheels on my car. In the rear, I'm running 20x10 +39 which is more aggressive than the wheels in the ebay auction. I did have to shave some of the fender in the rear. With a +44, you might be able to get away with some minor shaving.
Originally Posted by jaralar
It looks like a great deal. Have you contacted the seller as to how the wheels got damaged? That is a pretty big chunk missing from the wheel.
Well the wheel looks like it has a small dent in it, but the tire sure it missing a pretty big chunk. I'd contact the guy and ask for better picutres of the damage.
Originally Posted by bluelex
I had that same exact offset +44 on a 20x10 rear when I had the Donz with the same Nitto Tire. They will fit no problem, no need to do anything to the fendors.
Originally Posted by skpark70
Nice wheels,
Have you calculate shipping, I was just curious and calculated to my zip 98662 and shocking $547'
