Gs400 19" Offset/width for gs
Hey guys,
If i was going to order 19" iForged Senekas for my GS400, which i would want to put 40 series tires on, what offset should i get.
I might also wanna get supra TT brake calipers in the front however, if it makes it so that there is no lip, i will pass that option
basically its gonna be 19x8 19x10 on 40 series tires
id like the look to be like this https://www.clublexus.com/forums/sho...d.php?t=204398
maybe be able to lower it a bit more than him.
i have stock kit right now but will try to buy sideskirts and front lip
If you're doing a 10 in the rear you definitely don't want to go lower than a 38 offset....you may want to go even higher dependent on how much you're going to lower the car.
My wheels are 19X8.5 37et and 19X10 45et and were made specifically for the GS.
Here is a rear shot.
https://www.clublexus.com/gallery/sh...g/ppuser/39281
When you order from iforged they dont give you the offset unless you ask for a "custom" setup. Just make sure you get a High Disk option for the fronts so you can run the TT brakes. I have 19" iforgeds with TT brakes and still have some lip in the front.
do you know the offset of your rims ?or did u just order from d2/iforged and got them automatically set.
Originally Posted by will33184
what size tires do u have on ur wheels, /35? and also you dont know if that will clear the supra tt caliper right?
thanks for the help!
If you are going to go with IForged read my post about the valve stems. Make sure you go with the three piece wheels.
https://www.clublexus.com/forums/sho...d.php?t=202412
exclusive matchup
i have a full guide up in the tire forum (at the top of this forum), please go and read, it has all the info you need
Spartan
Wheels, Tires & Brakes Forum
11-27-01 09:00 AM
