Busted head of wheel lock nut SC400
Old 02-17-06, 06:26 AM
dbullen
dbullen's Avatar
Default Busted head of wheel lock nut SC400
Looking for any suggestions. In trying to remove one of my wheels I accidently busted the head of the wheel lock nut. Just enough so that when I put the lock key over the nut now it slips when I try to loosen it. See pic below. I bought this tool that is suppose to remove the nut, I hammered it onto the lock nut then tried to loosen it but the tool just loosens right off the nut and doesn't bring the nut with it. http://www.kentool.com/tireserv_UE.htm
Just looking to see if anyone has any other ideas..
Old 02-17-06, 06:52 AM
/Aerostar\
/Aerostar\'s Avatar
Yea my wheel lock key actually busted once. Tire Kingdom was able to get off 3 of em for free then Toyota got the last one off for $20
Old 02-17-06, 06:59 AM
SWSC400
SWSC400's Avatar
try some liquid wrench, let it sit on there a bit. If the tool keeps slipping, you might want to take a cold chisel and put some burrs on lug nut so the tool will grip better.
Old 02-17-06, 07:00 AM
dbullen
dbullen's Avatar
Default Tires
Only problem with mine is the tire on that rim is blown, so I can't drive the car.. I have a set of 4 16" rims with tires on them I was trying to swap out. So if I can't get the bolt off myself looks like i'm going to have to tow it. However I talked to the lexus dealership and they said they only way they were able to fix the problem before was by either drilling or heating up the nut and they usually damage the rims..
Old 02-17-06, 07:01 AM
plex
1UZFE/2JZGTE
plex's Avatar
That's weird same thing happened to me when I had chrome GS400 wheels on my SC. I bought a socket and forced it over the lock nut and took it off that way.
Old 02-17-06, 07:35 AM
kietlander
kietlander's Avatar
gator grip...
Old 02-17-06, 08:27 AM
dbullen
dbullen's Avatar
what size socket did you use? I tried a few but couldn't get them to pound over the nut.. The lock set is a factory one I purchased from the lexus dealer..
Old 02-17-06, 08:57 AM
plex
1UZFE/2JZGTE
plex's Avatar
I can't remember I bought a cheap set and pretty much tried different sizes and hammered it on the lock and then took it off.
Old 02-17-06, 09:07 AM
soarer5780
soarer5780's Avatar
thats how i do it too
Old 02-17-06, 10:40 AM
salimshah
salimshah's Avatar
What ever method you use .. gator grip, pipe-wrench, wis-grips etc ... just put the other 4 nuts on, and torque them properly. Then try to tackle the wheel-lock.
Why: This releives the tension on the offending bolt and should make it easier to budge.
Tip: Always use anti-sieze on lug bolts. Toque the lock-nut last and it should be the first one you loosen.
Further .. looking at the picture the bolt/nut/rim-hole looks odd. Seems there is a gap for the rim to be moved. If so try to budge the rim. [Just be careful if the car is on the jack]
Salim
Old 02-17-06, 10:47 AM
95 Integra
95 Integra's Avatar
http://www.sears.com/sr/javasr/produ...+Taps+%26+Dies
My brother had the same problem on his rsx and had to drill the lug out from the back side.
BinaryJay
11-12-13 09:51 PM
718LS430
02-21-11 05:26 PM
jackmack
12-17-10 09:16 PM
yellowssm
06-27-06 04:51 PM
ARISTO*7
01-10-05 03:14 PM
Quick Reply: Busted head of wheel lock nut SC400
