18" balancing.
Old 01-25-06, 07:00 PM
SilverBolt
SilverBolt's Avatar
Default 18" balancing.
I just had a set of Conti-all season tires mounted on our IS350. The tire guy (America's Tire) noticed that both the front wheels had a ton of lead on them to balance the tires from the factory. No exageration, like 6-8 onces per wheel. The rears were no bad, 1-2 onces. Well they dismount the stock Dunlops and get all the Conti's mounted then head to the balance machine. The throw a front on and spin it up. I was watching the wheel for runout and saw no visable runout at all. Sure enough the first one takes 4 onces to balance. That is crazy. That should be well beyond a manufacturer's specification. They break the wheel tire back down and rotate it on the rim 180 degrees. Rebalance and get the exact same results. Toyota/Lexus seems to have some extremely poor cast wheels to be that far out. I had no plans to invest in aftermarket wheels but I may have just changed my mind. Side note these wheels weigh a ton. I didn't have a scale handy but the rears feel like 30+ lbs. Curious to see if anyone else can see how much balance weight is on their wheels. All the weights are on the inside so it is a little tough to see. Anyone else in the same boat?
Old 01-25-06, 07:27 PM
Cleric
Cleric's Avatar
Tire tire pressure sensors also add to the mass of the wheel.
Old 01-26-06, 06:40 AM
SilverBolt
SilverBolt's Avatar
The tire sensors weighs about 3 onces. There is a machined area on the wheel where the sensor sits. The material removed for the sensors weighs the same as the sensor. So I know it's not that. Plus I just had a set of BBS wheels with sensors mounted up for my Tacoma. They took less than 1 once of lead to balance a 33" all terrain tire. It's the wheels.
SkyPara82
RC - 1st Gen (2015-present)
11-09-17 03:10 PM
sarah
07-22-15 11:41 AM
NickTee
ES - 5th Gen (2007-2012)
05-15-15 12:27 PM
istundra
01-20-12 10:48 PM
DrComputer
08-24-05 08:04 AM
Quick Reply: 18" balancing.
