what offset fits 2000 GS400
i was looking at Works VS-XX. i will have 13.1in brembo big brakes in the front and stock rear brakes. and i also plan to get tein CS. does anyone know what offset and width i can run if i get 19in wheels? i would like the most lip possible. i would like to avoid fender mods at the same time.
Thanks guys!
Thanks guys!
ok. i've been looking at http://www.lgwnorcal.com/articles/WheelFitment.shtml and i like the 19x9 +38 and 19x10 +42
the problem now is i still need to find out how to get high disk setup , and if brembo bbk will clear the size above
The One
Originally Posted by ShaneC
o
Work has different disk fitment.
You want the R-disk.
The One
is there anything i need to worry abouut if i run 19 in the front and 20's in the rear. or if i run 18" front and 20" rears?
If you do the former, than the diameters will not match. Our GS are not setup for running wheels with different diameters. Cars (like the vettes for example) that have staggered wheel sizes/diameter are calibrated to work with these different diameters.
There have been previous discussions on this and things like wheel rotation being different, doing weird things to the odo, speedo, abs, brake sensors, ...
All in all, I would avoid it. Just my .02.
ic. thanks Neo good to know its a bad idea to run different diameter front and rear.
rominl.. thanks for the write up. its so clear and will done. i learned so much from it..
this forum keeps on impressing me.
Hameed
Wheels, Tires & Brakes Forum
12-01-13 05:02 PM
