would these wheels fit?
Old 01-02-06, 05:42 AM
suprat04r
suprat04r's Avatar
Default would these wheels fit?
would work equips 19x 9 with a +26 offset (front)
and 19x10 with +20 offset (rear)
if not would i be able to fit a 315/40/19 on the rear rims itself (doesn't have to be fitted on the SC, just the rims itself or are the tires too wide)?
Old 01-02-06, 07:08 AM
SWSC400
SWSC400's Avatar
you should use a 11"-12" rim for that size tire, I think 10" would be pushing it a bit. A 285 would work and maybe a 295....and just FYI, those also cost about 400 bucks a tire!
Old 01-03-06, 01:12 AM
suprat04r
suprat04r's Avatar
yep they are $$$! i already have a pair and i want to use them... they are good year super car tires and i'm surprised you know them! i love how tall they are and wide!
reason i ask is because it SHOULD fit on my 94 supra turbo (with veilside over fenders +1" each side)
but was wondering if it'd fit a SC400 (the work rims with those off set of course)
Old 01-03-06, 07:46 AM
SWSC400
SWSC400's Avatar
...all I can tell you is the 10" width is probably not enough, the Tire Rack website says 11-12" for that size tire, which sounds right to me also. You wouldn't want to squeeze a bigger tire on a rim that is too narrow it becomes unsafe. As for the offset of your rear rim fitting on the SC, from what I have read on here sounds like it may not work, I think you want to be up around 35mmish, but you can do a search and maybe ask some of the others on here that are more knowledgable than I about this...sorry, wish I could be of more help.
webmonst3r
GS - 1st Gen (1993-1997)
24
04-29-13 09:04 AM
818GS
06-15-12 09:34 AM
pashazero
07-04-10 11:43 AM
twofiddy
12-10-08 07:09 PM
MrMark
07-27-06 10:09 AM
Quick Reply: would these wheels fit?
