could a 305/35/18 fit on the back of a sc300?
Old 12-27-05, 07:53 PM
flossn
flossn's Avatar
Default could a 305/35/18 fit on the back of a sc300?
I just bought a 92 sc300 for a street/strip car and have been searching for wheel fitments. I've seen a few threads where people have fit 295/35/18's but no mention of 305/35/18's. Reason being, i'm looking to put drag radials on and would like wider tire. I've narrowed it down to a few rims and from what i've read i should go with a 18x11 or 18x10 but not sure what offsets yet. I'm looking at the nitto 555r 305/35/18 vs a bfg drag 295/35/18 if that helps.
I was also considering a wide 17" setup for weight savings, but i'm afraid they would look too small on the sc.
Thanks for any help!
Tony
Old 01-01-06, 10:00 AM
exvelocity
exvelocity's Avatar
just roll the wheelwell pinchweld and you'll be good to go,that is if you're going with wheels that are close to factory offset
Old 01-03-06, 02:47 PM
flossn
flossn's Avatar
Isn't the stock offset like +50? Wouldn't that stick out a lot?
from what i've been reading, people are running +38 on a 18x10 wheel and are fitting 285's.
g35driver
07-13-10 08:34 AM
BMwhat?
SC- 1st Gen (1992-2000)
06-20-05 10:19 AM
Hi-psi
09-10-03 05:32 PM
Hi-psi
06-10-03 12:11 PM
Quick Reply: could a 305/35/18 fit on the back of a sc300?
