Fitment Q: 19 Lexion 203s on a SC430?
I'm thinking of getting Lexion 203 rims in 19 X 8.5 with +24 OFFSET for the fronts and 19 X 10 with +35 OFFSET for the rears.
Does anyone know if this would fit on a '02 SC430? Would this cause the wheels to stick out too much or line up with the fender line?
Thanks
Josh
Thanks
Josh
Thanks Henry,
I'm not as experienced in rim calculations as you are from your rim post. Do you know how far in (from the fender edge) the wheels will be when mounted?
Is the formula [(aftermarket wheel width inches)*(2.54cm/in)/2-(aftermarket wheel offset cm)]-[(stock wheel width inches)*(2.54cm/in)/2-(stock wheel offset cm)]=the difference in distance in cm that the new rim will stick out further than the stock rim?
If that's right, then I can run through the calculations myself.
exclusive matchup
haha, let's see.
assume the typical 9 +24 and 10+24 setup, which is almost max out already without any fender work. you are asking about 8.5 +24 and 10 +35. so the front is 6mm more inboard and the rear is 11mm more inboard
and yeah, the equation you put up is valid
but i can do the calculation for you. i believe the stock wheels are 8 +45. so with your setup, the front is 27mm outboard (a bit more than 1inch, and the rear is 35mm outboard (1 1/2 inch)
Thanks
Josh
Thanks
Josh
Those offset should be fine.
I currently have 19x9 with +26 offset 19x10 with +26 offset Exxe wheels. No Rubbing.
I use to have 19x9 with +26 and 19x10.5 with +29 offset Maya GR5 and I still did not have any rubbing.
luciano
04-14-06 04:56 PM
