Need spacer advice
Need spacer advice
Need some help.. my dad's 93 Camry has some 15" steelies on them and the tires were getting bare - so I suggested that he get a set of 16" tires and use the stock 16s from my GS400 since I was going to upgrade my wheels anyways. Unfortunately, the offset on the rear was too high and there is severe rubbing on the rears. I purchased some 5/16" (8mm) universal spacers from Pep Boys and that temporarily solved the problem. However, now there is a bit of subtle rattle and wobble coming from the rear at normal speeds... which is very noticeable when you have a drink with ice in the cupholder (There are no problems going over bumps though). Searching on the boards, I've learned that this is a common culprit of spacers..
my dad knows nothing about cars, so I'm feeling a bit sheepish at creating this problem.. my options are:
get a set of hubcentric 15mm wheel adapters (not sure if there is enough space, or if it might mess something up with a wider rear in a front wheel drive car?)
eat the cost of the 16" tires and purchase/mount/balance a set of 15s on the stock ones
find a mechanic and maybe they can "center" these on the spacers?
any one have any suggestions? thanks. i'm also not that great with cars, so dumbing it down would be appreciated.
808mcv20l
12-15-15 09:49 PM
GRANYZ400
Suspension and Brakes
02-04-13 10:57 AM
