Tire pressure
Old 09-14-05, 02:21 PM
AJ
AJ's Avatar
Post Tire pressure
I just found after noticing the ride quality has been crappier THAT the tire pressure is 25 psi , so i wanted to see whats the perfect tire pressure for me
Oh my tires are Dunlop SP Sport 9000 225/40/ZR18
Any help is appreciated
Old 09-14-05, 03:01 PM
rominl
exclusive matchup
rominl's Avatar
even the spec on the stock 17s are 32psi, how you can run anything lower than that.
i think you can run 32psi, that's the factory spec on 16s and 17s if i am correct. but for 18s, i might put it at around 35psi to give it more pressure.
Old 09-15-05, 02:32 AM
AJ
AJ's Avatar
Thanks man
Old 09-15-05, 02:59 AM
Lexusfreak
Lexusfreak's Avatar
Cool
I concur.
Old 09-15-05, 06:37 AM
juniorsdad
juniorsdad's Avatar
running the same tire size @ 35 psi all around
Old 09-15-05, 04:32 PM
SCRUFFDOGG
SCRUFFDOGG's Avatar
I run a 245/40/18 Toyo T1-S on my truck at 40 psi. Don't even think about going less than 35 psi but if you're still not sure call around to a few tire shops and get a consensus.
Old 09-15-05, 04:52 PM
AJ
AJ's Avatar
I called and they all agreed that 34-35 is the best thanks for the help guys
robsvdp
02-06-12 11:57 AM
edinburger
10-25-09 07:11 PM
GTSLEX
10-24-05 07:20 PM
IJOCKGS
02-03-05 01:27 AM
LXOGOOD
06-29-02 10:48 PM
Quick Reply: Tire pressure
