Would you put the tires with the most tread in the back?
Hi
My wife took her car into dealership last week and they rotated the tires and gave her a 70 k
service. This week I took her car to a local tire shop to have the 3.76 LSD installed (99GS400)
The local tire shop guy calls me up saying the front tires only have 50% tread left and do I want them put on the rear.
So we get into a discussion of where the tires with the most tread should be. He thinks that because of the weight of the engine the front should have the most tread. I think that because it is rear wheel drive the rear should have the most tread.
I called Lexus dealership and talked to my buddy there and he said they had just had some expert come out and tell them put the most tread on the axle where the traction is.
What do you guys think?
Ivan
3dog
Ivan
3dog
The old school thinking has been that the front gets the most abuse and for directional stability and braking, put the tires with the most tread in the front. For rear wheel drive obviously the push would come from the back, but it is the only factor. This has been challanged by the new study which claims directioal stability is very much affected by tires in the back.
This study from a major tire manufacturer (Dunlop or Michellin .. I dont remember) but if you go to Discount Tires, they have the counter savers (similar to screen savers) plastered with this info. So when I got a pair of new tires and asked them to install them in the front, the guy lectured me for 0.5 minute ... which ended with ,, so you want to go against the study ...
Needless to say that I went with my old school ways. As long as the tires have reasonable tread, they will work just fine .. not necessarily optium .... irrespective of where you instal them.
Salim
Salim
Zombie Slayer
I'm with the guys here that the drive wheels get the better tread.
As for a blow out??? Not gonna happen with 50% tread. Unless your running on a slick and start having belts show through, no worries.
My feelings are: Dry conditions, irrelevant, 50% reduction in tread will have no bearing on traction. We're talking about rubber on road surface here. Traction remains the same. Tread REALLY comes into play in inclement weather. Some reduction in grip in the front will result in increased understeer. Reduced traction in the rear means increased oversteer, or a spin-out. Couple that fact that our cars are RWD, all make ample power, a little rain, poor tread in the back and WOOPS, off the road. A little slip in the front can be corrected with either very slight braking (to shift more weight to the front), or a blip of the throttle to use the rear to correct the front.
Just my .87 (it used to be .02, but I've raised prices like the gas companies)
Originally Posted by GRAND_LS 4
Personally, i would put the ones with the most tread in the front.... we all know what happens if the front blows...
Zombie Slayer
Here's some info I found online:
from Policedriving.com
When buying just two new tires, should they be put on the front or rear?
When radial tires are used with bias or bias belted tires on the same car, the radials must always be placed on the rear axle. When you select a pair of replacement tires in the same size and construction as those on the car, We recommend you put them on the rear axle. A single new tire should be paired on the rear axle with the tire having the most tread depth of the other three.
Goodyear.com
When radial tires are used with bias or bias belted tires on the same car, the radials must always be placed on the rear axle. Never mix radial and bias-ply tires on the same axle. When you select a pair of replacement tires in the same size and construction as those on the car, we recommend you put them on the rear axle. A single new tire should be paired on the rear axle with the tire having the most tread depth of the other three.
Back to Top
Michelinman.com
Where do I install new tires if I only buy two?
If you're replacing only two tires, be sure to have them installed on your vehicle's rear axle. New tires will provide better grip than your half-worn tires and when they are installed on the rear that helps reduce the potential for your vehicle to fishtail or hydroplane in wet conditions.
Plus, go to michelinman.com (Michelin tire web site) and under the tips section, you will find the area about purchasing 2 tires and where they should be mounted. Watch the video and you'll never mount those tires on the front again.
Goodyear.com
Back to Top
Michelinman.com
Former Sponsor
Tires front or back
Thanks for all the comments everyone.
My wife and I both have 99 GS400.
As I stated before she just got the 3.76 LSD.
I've got that plus a torqueconverter and a
RMM Supercharger 360 rwhp.
So rear wheel traction is very important.
I did like what I6turbo said about hydroplaning.
We live in Seattle Washington and it rains alot.
Not just once in a while either.
In the winter months the roads are wet most of the time.
So we both have Michelin Pilot Sport A/S 245/45/17, I saw they were rated really high on the tire rack for wet driving and resistance to hydroplaning.
We've had the cars a couple of years now and those tires worked really well in the wet conditions and whenever it drys out.
If the car starts hydroplaning because 50 % tread is not enough I guess we will replace. I'm hoping to get thru this winter and maybe replace next spring with Mich PPS2
Thanks again
Ivan
3dog
Thanks again
Ivan
3dog
Call me stubborn, or just making my own decisions based upon my experience, but despite what the tire mfg. web sites say, I STILL will put the most tread on the front in most cases. I think the advice on the tires mfg sites is irresponsible because hydroplaning is more likely to begin at the front wheels, plus, MOST cars nowadays are FWD, which makes the tendency that much worse. The Michelin site, for example, seems to assume that the car in question is RWD as they are talking about fishtailing (giving them the benefit of the doubt for not thinking that the rear will fishtail under no power).
FWD cars with less than great tread are VERY suseptible to hydroplaning. I've experienced it myself and it's damned dangerous. I was driving on I-40 between Knoxville and Nashville in a Nissan Maxima. The Maxima had the original Bridgestone tires on it, and they had worn to the point that there wasn't much depth at all on the outside shoulders (but they weren't yet worn to the wear bars). It had obviously been raining a few minutes earlier, but wasn't actually raining at the time. I was driving about 75 MPH, and all of a sudden the front end started drifting off. I eased up on the throttle, gently tried to bring the car under control, but it got crossed up anyway. It went back and forth a couple of times, getting more broadside every time. I was just about to slam the brakes and hope for the best because I thought it was gone, but just then it didn't come around as far and I was lucky enough to bring it back under control. Not bragging, but when I was growing up I had a lot of experience driving like a maniac on gravel and dirt roads and the occasional icy road, and deliberately putting vehicles in that attitude, so I suspect I was able to bring the car back under control when 99% of drivers would not have been so lucky. That experience taught me that the tires with the best traction go on the front. Reason tells me the same, even on a rear drive car.
Thanks again
Ivan
3dog
Thanks again
Ivan
3dog
Depends??
Maybe it is supposed to be:
- New tires on rear for RWD
- New tires on front for FWD
So for us RWD lexus owners I would think putting the most tread on the rear.
I've noticed how much power the V8 engines have and can easily spin the rears, so if you dont keep good traction in the back while flooring the gas u may experience some sliding.
Unless the other set of tires on the front have very poor tread -- that would be extremely dangerous under any circumstances because it reduces traction for turning.
BlueCrabby
Wheels, Tires & Brakes Forum
10-29-11 08:00 PM
Wald GS
07-28-03 07:57 AM
