what is the proper 20" wheel/tire size for gs400?
#32
Originally Posted by Neo
To keep the overall diameter the same as OEM, TireRack is right. You want 30 series.
BUT
Most run 35 because
1. For a long time there was not much selection for 30 series tires to fit out car. There is a little more now but still not great. Less choices also equals premium cost for the ones that are available.
2. The sidewalls with 30 series will be very thin. Ride quality would suck even worse. Wheel damage would have higher chances since there is even less rubber protection. The sidewalls are stiffer but there is just less of it.
BUT
Most run 35 because
are there any abs issues?
thanks neo.
#33
The One
Originally Posted by Benjamin T
noob alert... but aren't the rears already 30-series? i thought rears would have to be at least 275/30/20?
The sizes are not WAY out there so abs should be OK.
#35
Actually, I'd stay in the 40s with x10. I have 20x10 +38 with 275s and I had to shave the fender. Other than that, bluelex's numbers are good. Here is some good reading for "safe" sizes:
https://www.clublexus.com/forums/sho...d.php?t=115165
#36
I have a 2007 GS350. My goal is actually 255/35/20 & 285/35/20 with front:+38 and rear:+43....is it possible? do I really have to go with 30 in the rear? BTW, i'm NOT going to lower the car, what would be the best width of wheels for my setting?....thanks for the help!!!
#41
OK, here is my final decision....HAHA. How about 20 X 9 +38 in front with 255/35/20 or 245/35, and the rear is 20 X 10 +43 with 285/30/20? w/o lower the car or any fender works. Will that be too aggresive? will the rear be too stick out the fender? Thanks for your helps....
#43
I'm sure you will get alot of different opinions on this but I'll tell you waht i have and they fir perfect Nice and flush and they don't stick out passed the fender... Here ya go
Front- 20x8.5, 38 offset and 245 35 20 tire
Rear 20 x10, 42 or 43 offset can't remeber, 275 30 20 tire..
Hope this helps.... Good luck on the quest for wheels
Tony
Tony
