Offset question
Offset question
Hi,
What is the most aggressive offset you can fit in the front and the rears of sc430's???
The wheel shops tell me the lowest I can go is ~+35mm for 9.5 to 10.0 width rims.
Is this true?? Or can I even go w/ something like +20mm??
TIA
TIA
Originally Posted by uturn2hell
Hi,
TIA
TIA
That depends on the rim size, too, right?
I'm running 25mm spacers up front with my stock rims and 245/45 tires, and I get the slightest bit of rubbing when the springs bottom out. Dialing back to 20mm would probably be ideal.
