Spacers????
Old 06-20-05, 10:42 PM
OGS
OGS's Avatar
Default Spacers????
Anyone got some inputs on wheels spacers?
My car is getting test fitted for a new set of BBK and they need an additional 5mm clearance in the front.
I know that 5mm isn't much, but I have never used spacers and wanted to see if some of you could give me some feed back!!!
Thanks!
Old 06-21-05, 05:52 AM
Lexis11
Lexis11's Avatar
That is what I needed when I just added my BBK and there seems to be no problems, I forget they are even there to be honest with you. I have the anodized H&R spacer so you can't really see them behind the wheel.
Old 06-21-05, 09:59 AM
DXC
DXC's Avatar
Thanks!
5mm, NO PROBLEM! 20+ might cause... Go for it
Old 06-21-05, 09:14 PM
bluelex
bluelex's Avatar
a 5 is no problem its when you go over 15 that i start to worry up front..enjoy the new bbk.
Old 06-21-05, 09:54 PM
BUSTN
BUSTN's Avatar
I can do a 5mm spacer without putting on longer studs,right?
Old 06-21-05, 10:09 PM
bluelex
bluelex's Avatar
Yes............
Old 06-21-05, 11:12 PM
rominl
exclusive matchup
rominl's Avatar
depends on what kind of wheels you have. if you have stock wheels, yes. for example on my hre, with the wheels on, i can only make couple of turns on the lug nuts (compared to 11 turns stock). with the 5mm you gotta be careful
so it's a wrong assumption to say that if it's 5mm then you are good to go with stock studs. nop, you need to take other things into consideration
Old 06-22-05, 05:42 AM
Lexis11
Lexis11's Avatar
With my iFORGED wheels I put the new studs in just to be sure.
Old 06-22-05, 10:45 AM
Neo
The One
Neo's Avatar
I tried a 5mm spacer on my rear when I had my L-Tuned wheels and I lost about half, meaning I only had 5-6 lug rotations.. I took them off until I could get longer studs. I ended up getting new wheels so it became a moot point.
My point is that if you are going through the trouble of nice wheels and BBKs, I'd invest in good hubcentric spacers and longer studs.
Old 06-22-05, 12:52 PM
rominl
exclusive matchup
rominl's Avatar
very well said, spend the extra money to do it right (or do it better)
Old 06-22-05, 01:03 PM
GSing430
GSing430's Avatar
i had 5mm spacer but decided to ttake them off until i have time to replace my studs, i f i remember it correctly, i only get 3-5 full turn with the spacer, it didn't feel safe to me.
Old 06-22-05, 08:45 PM
AME_VIP
AME_VIP's Avatar
see if you can get away with 3mm spacers. I'm runnning them on my SC4 to make my front wheels a little more flush and there were not that many turns with the 3mm.
Old 06-23-05, 10:44 AM
Lexis11
Lexis11's Avatar
Yup Neo you are correct, I was like should I try to leave the stock studs on and maybe make t safe or just put new studs in and have plenty of room. I chose to add the new studs.
Old 06-23-05, 11:05 AM
islandboi
islandboi's Avatar
Kics Project spacer's are really good too. they come with extended studs, and various mm's too.
Old 06-23-05, 04:51 PM
AME_VIP
AME_VIP's Avatar
agreed
I have a pair of 15mm kics that I use for other wheels. very nice product
lexodude
03-14-07 06:06 PM
sc.Fred
Suspension and Brakes
29
09-23-05 08:01 AM
One HoT
General Classifieds
17
06-08-04 07:51 PM
Quick Reply: Spacers????
