245/35/20 on a 9.5" wide rim
Old 05-13-05, 11:20 AM
Jasoneo5
Jasoneo5's Avatar
Default 245/35/20 on a 9.5" wide rim
Hey all,
Will a 245/35/20 fit on a 9.5" wide 20" rim?
Also, I have a screw in my 275/30/20 tire, and I was told that I cannot get it patched because of the tire. It is right in the middle of the tread. Let me know,
Thanks,
-Jason
Old 05-13-05, 12:02 PM
Neo
The One
Neo's Avatar
The tire will fit but it will be stretched. It is at may tire manufacturer's max. Usually, the range is 8.0 - 9.5.
As for the repair, that is true. I have a similar situation. Optimally, you want to replace it but if it is not leaking, it should be OK for awhile. Whatever you do, do not remove the screw otherwise, it is replacement time.
Old 05-13-05, 01:04 PM
rominl
exclusive matchup
rominl's Avatar
yeah some performance tires that's bad and you might need new tires. some you can patch them though.
and 245 is pretty stretched on 9.5 i suppose. it's doable
Old 05-13-05, 02:27 PM
Lexusfreak
Lexusfreak's Avatar
Red face
Originally Posted by Jasoneo5
Hey all,
Thanks,
-Jason
WOW! That's alot of tire!
superdenso
09-03-16 12:30 AM
yangaroni
GS - 1st Gen (1993-1997)
03-08-12 04:26 PM
msgs350
05-19-10 01:55 PM
ktang235
12-20-05 09:40 PM
BUSTN
01-30-05 09:13 AM
Quick Reply: 245/35/20 on a 9.5" wide rim
