Tire size help??
Old 04-18-05, 02:48 AM
silversprucesc3
silversprucesc3's Avatar
Default Tire size help??
I picked up a set of Rx300 rims .... 16" x 6.5" for the es300....
IF i decide to keep them my plan was to change the tires and throw on the es3.
What size tire should I use??
Old 04-18-05, 01:07 PM
silversprucesc3
anyone ???
Old 04-19-05, 08:40 AM
Lexusfreak
Lexusfreak's Avatar
Red face
Not sure the RX rims should go on the ES. Probably why you haven't got a specific response yet.
Old 04-20-05, 12:07 AM
silversprucesc3
I thought the RX300 wheel is a 35mm offset therefore at only 6.5" wide should fit on the ES... I realize the optimum is 40-50mm offset on an es but it should work>>>???
Old 04-20-05, 12:22 AM
rominl
exclusive matchup
rominl's Avatar
do you know if is300 wheels will work on the es? from what i heard the rx wheels and the is wheels they are almost like interchangeable
Old 04-21-05, 08:33 AM
slickgt1
slickgt1's Avatar
For future referance, you can just go here. And match up the tire sizes for different rims.
http://www.miata.net/garage/tirecalc.html
Old 04-21-05, 08:58 AM
rominl
exclusive matchup
rominl's Avatar
well the tires won't match for sure. i think the problem is more about the offset
tcorbettoc
11-02-12 08:39 PM
skotter
03-22-09 01:58 PM
crocair
RX - 1st Gen (1999-2003)
04-09-08 12:26 PM
phins42
07-09-07 11:04 AM
92Es300 5sPd
16
09-23-02 09:34 PM
Quick Reply: Tire size help??
