HELP, Cant remove wheel lock
Old 04-17-05, 03:52 PM
technol
technol's Avatar
Default HELP, Cant remove wheel lock
to make a long story short my aftermarket wheel locked was way stripped and wouldent remove, so i started chiseling it with an air hammer, hoping to split the lug. to make matters worse i have 3/4 struts/ shocks changed to aftermarket supra tt/ eaibach combo. so any ideas on how i can break the stud, or somehow get this son of a ***** out? thank you so much for your help!
Old 04-17-05, 07:51 PM
johnnyt
johnnyt's Avatar
take it to a rim shop and have them cut the lug nut off.
Old 04-18-05, 12:09 AM
rominl
exclusive matchup
rominl's Avatar
or you can try to JAM a smaller hex socket on the lock
Old 04-18-05, 09:24 AM
HKS_GS430
HKS_GS430's Avatar
depending on the type of lock you have, you may be screwed.
Old 04-18-05, 03:32 PM
jpcdmd
jpcdmd's Avatar
if you could somehow cut a slit in the end of it, then unscrew it with something much like you would a flathead screw.
IXI187IXI
08-18-14 08:37 PM
BinaryJay
11-12-13 09:51 PM
jackmack
12-17-10 09:16 PM
yellowssm
06-27-06 04:51 PM
dbullen
02-17-06 10:47 AM
Quick Reply: HELP, Cant remove wheel lock
