HRE or Volk?
Tired of looking at all the possibilities, want to spend some money and looking for advice from people with experience. 18’s 8.5 front 10 rear. Appreciate the help!
Lance
Lance
volk, my choice
choosing wheels for your lex is a love affair-either you love them, or cannot stand them.
both hre and volk are mafd. by very good co.. how you like your rims are a very personal matter. if you have the $$$ and like the look of hres, go for them.
any of the volk wheels is just as well built as the hres, if not better. personally, i like the volks more than the hres. the reason being that they are lighter, more attractive(imho), and the prices are more justified. but, if you cannot find anything in the volk wheels you desire, it does not matter how cheap they are.
as far as vibration prob., make sure you go to a shop that has the latest balance machine and try to buy lifetime balance.
volk wheels are still high line products, one of the best in the world. they are the com. that make oem rims for many tuners, such as trd japan.
$ for $, volk would be my choice.
Guest
Posts: n/a
I couldn't agree more with gs4will. I was in the market of wheels not long time ago. I had been struggled between HRE, RH, and Volk. After I saw HRE on Lexus, they aren't as good as I thought they would. For the best value, you couldn't go wrong with Volk. As gs4will mentioned, they are light and the quality is up to the bar. The rest is just personal taste whether you like their style or not. Good luck on your journey for the perfect rims.
OZ Opera's
I personally love the OZ Opera's that I have on my car. They are 18-8.5 fronts running 245-40 and 18-10 rears running 295-35 SO2 Pole Positions.
If your suspension is stock stay with the 285-35 diameter and you should have no problem.
Now comes the tricky part. Make sure you find a qualified shop that has the latest wheel balancers and alignment equipment from Hunter. You will drive your car knowing it is really balanced correctly. The GS's are notoriously stubborn when it comes to balancing so you have to be careful where you go......
Yeah VolkRacing is really great wheels. I haven't seen any HRE wheels in person, but I can assure that at least VolkRacing's quality and looks won't be any less.
Both Enkei and VolkRacing are great manufacturers. They both make wheels for O.E. uses, and VolkRacing makes lightweight racing/street wheels for TRD, MazdaSpeed, STi, and Nismo. Don't forget to mention their own line of RAYS wheels, which includes the famous TE37 and all F-Zero series.
It's all up to your personal opinion on the looks. If money isn't the matter, look at all the wheels before lookin at the brands.
Other companies you should take a look at:
Enkei, Works, Advan/AVS, OZ.
Just my 2 cents...recently I've placed an order for a set of HRE 547's, 18X8.5 front and 18X10 rear. I like Volk AV3 too, but since someone in the Bay Area already has a set, I am getting the HRE's. Their polish finish looks really good.
GO VOLK!
Hi Lance,
So you didn't like the SSR's at all? Well my friend, Volk and HRE are truly great wheels. I particularly recommend the 18" TE37s , I think this wheel from the Volk line has no competition quality wise (except for Volk's own TE37 MAG). The entire structure of this wheel is made of true forged aluminum (not semi-solid-forging as SSR), giving them superior strength were really matters- specially the inner lip (where the highest stresses occur). This forging method requires extremely advanced tools and machinery. In contrast, HRE's are forged only at the center (they simply forge a big cylinder and then machine the center off) with spun rim halves, although these are interchangeable given their multi-piece construction. Also, you won't find a lighter aluminum wheel in the market , HRE's are about 7 pounds heavier. Compared to the stock 17", and with 265 rears, I saved 30 lbs. in unsprung weight (due also to the lighter Toyo tires), and this truly pays dividends in ride quality, handling and acceleration. Perhaps the TE37's are not as flashy as other polished multipiece wheels but I like their simple, form-follows-fuction design better.
HRE 547 weight
gs4power, how heavy is your Volk TE37? I was told that the HRE 547 18X8.5 is about 21 lbs, and the 18X10 rear is about 24 lbs. If the TE37 is 7 lbs lighter, it would be about 14 lbs, which seems very remarkable if it's true.
Wheel weights
Wheel weights, source: HRE , Macking Industries and my own scale
18" x 8.5 HRE 445 23 lb (The three piece 5xx series might have a similar weight)
18" x 8.5 TE37 16 lb
18" x 9.5 TE37 17.5 lb
Stock GS400 17" 23 lb
Pic
Sure pal!
These are silver w/centercaps... I LOVE THEM I'm thinking on blue brake calipers... behind the Volk decals on the wheel spokes they would look sweet!
Globe, I have 3 more pics... If you're interested email me at alias_mickey@hotmail.com...don't know how to post more than one pic in here.
