I'm considering stepping down to 19"s....(need offset help)
Loves Snickerdoodles!
Currently I have the IForged Flux in 20"s...thinking of going down to 19"s...
I was thinking somehwere along the lines of +32 in 10.5" wide wheel for the rears
and +32 in an 8.5" for the fronts. Do you think this would work?
*I know it's rather aggressive but keep in mind that I do have my fenders fully rolled and that I would be running a stretched tire set-up.
Thanks in advance guys,
-Seize
-Seize
exclusive matchup
what offset you have on 20s now?
i think the front will work no problem. that's just the same as mine. the rear i am not sure, that's just like my 10 with 26 offset. that's very low (i have 43 now and i know 35 is about the max with all fender shaved on 2gs). the 1gs is a bit more tolerant but i am not sure
The One
Originally Posted by babyboy
Rominl-
Is it possible to run a 10.5 with a +43 offsets on the rear (2nd gen GS) without fender mods? If so what size tire would you recomend.?
O.C. Lucky Strike Fanatic
Seize,
Stepping down cause the cut springs and ride quality on the 20's a lil harsh?
I'm sure you are aware that I'm running +23 in the front and +15 in the back, without any problems since I too had my fenders rolled as well as pulled.
You should be able to run +23 in the front with no problems at all.
In the rear you could do +20.
exclusive matchup
Rominl-
Originally Posted by johnee78
Seize, you can do a 9 in the front with a +30 offset and do a 10.5 rear with either +24 or 32..This set-up will work if you use stretch tires and rolled fenders which you have already done..
Ah yeah...just what I wanted to hear...good lookin' out Johnee
And thanks to everyone else for your input, I appreciate it
Originally Posted by rominl
the front, maybe, probably rub a little after you mod the fender
the rear? even you mod the fender i am not sure
