Are OEM Lexus chrome wheels chromed/finished on the INSIDE as well?
Just got a set of chromed OEM Lexus wheels and I would like to clean up and protect the inside surface, some of which is visible when viewing the mounted wheel. So I scrubbed them up real good (the insides, that is) with Scotch-brite and Comet. You can see the results below. Now I want to know how to best finish that raw alloy surface, so that future layers of brake dust are more easily cleaned off. I asked that question in www.autopia.org, a car-detailing forum. You can see the details of the discussion here:
http://autopia.org/forums/showthread...380#post518380
As you can see, a moderator has mentioned that "most chrome wheels are chrome on the inside too". Well, that's sure not my experience (see my reply to him?). But I thought I'd pose that question to you rim fans- aside from custom car-show chrome jobs, have you ever seen the inside of OEM wheels chromed?
And of course, if anyone has some suggestions on what I should use on the inside surface please let me know.
hey perry,
we're up late in CA today aren't we? But i remember my OEM chromes were NOT chromed on the inside. it was only the outside.
Everything in Moderation
My 17" stock chromes are not chromed on the inside.
Off the wall suggestion: If you were inclined to paint the inside of the rims, I'd use caliper paint, which will stick to aluminum and will hold up much better than a lot of alternatives. You might be able to get away without priming or clearcoating too.
Not off the wall at all!
That's not a bad suggestion, since brake caliper paint goes on thick and covers up the rough casting marks of a caliper, and the insides of my wheel were similarly rough. But I ended up following the crowd and used the Dupli-Color line of Adhesion Promoter, Silver Wheel Paint and Wheel Clear coat. You can see the details of what I did at this thread:
https://www.clublexus.com/forums/sho...d.php?t=156368
If it does not last long, and some have warned it won't, I may go the caliper paint route the next time around, or just let it go au naturel, like 99% of the cars on the road. But for now it looks fine:
