+33 Offset Possible On A GS?
The One
Originally Posted by rominl
he didn't do it the first night and he learned the lesson
exclusive matchup
Originally Posted by Neo
LOL. I had no tools to trim the fender (at the time ) and I had to get the new wheels down to jawnthen's house to test how much to trim. This means I had to mount the wheels. Just that 25 minute drive was painful.
Come on, guys. A little camber won't kill ya. D had his at -2 for a long time and he vouched there was no real tire wear that he could see.
My camber is MAXED OUT I think but that's only so I could clear the inner fender when I have the airrunner at the lowest setting. The ONLY reason I can do this is because I barely drive the car. Again, if you commute many miles daily for your work or chores, then of course, I would NEVER recommend anyone to do what I did. But, I will stand by what I said, you don't need a perfect 0 camber if your only worry was tire wear. Believe me, the tire manufacturers design their tires to take a lot of abuse, I mean, it's really the only thing that's between all that horsepower and the tarmac right?
Here's a pic, I didn't even bother shaving anything down, I just took off all the plastic lining... (this is +24 front and back by the way heehhe)
Hmmm... 24 you say..
edit: what size wheel do you have (width)? and what tire sizes are you running?
thanks in advance
thanks in advance
The One
Actually, Jon's wheels specs are:
Dronell BR version 2 3-pc forged
20x8.5 +24 /w 225/35/20 tires up front and 20x9.5 +24 with 245/35/20 in the back
** Taken directly from his wheel debut on CL:
https://www.clublexus.com/forums/sho...d.php?t=139704
exclusive matchup
Former Sponsor
I just dont want to end up in court when someone with a softer compound experiences wear and says "but D2-AUTOSPORT said it was fine!!!" I can speak from my PERSONAL experience, with the Nitto 555 the wear was nearly non-existent, I am getting another set of these tires based heavily on their durability.
exclusive matchup
Originally Posted by D2-AUTOSPORT
That was with Nitto 555 and no burnouts! (stock GS400 with exhaust will not spin those 275's!!).
