Patch or plugs to repair a puncture?
Old 02-26-05, 09:34 PM
RA40
Super Moderator
RA40's Avatar
Default Patch or plugs to repair a puncture?
What are the thoughts behind these two fixes? I've had tires fixed with patches and plugs but haven't understood which may be preferred or appropriate.
The other day I had the misfortune to find a nail in the tire. While it entered the tread at an angle, it was just enough that the tip did make it through the casing to cause a very-very slow leak.
The wild thought was to shoot that sealer goo into it but I don't want that mess inside.
Old 02-26-05, 10:19 PM
ChuH
ChuH's Avatar
Default Cemented One Piece Patch-Plug
The most recommended method for high performance tire repair is to use combination Cemented One Piece Patch-Plug type repair method. They look like a mushroom with a long stem and flat hat. That patch-plug is pulled through the punctured hole via a wire where the stem plugs the hole and the patch seals it further. As you drive and heat up the tire the stem vulcanize and provide a better seal. You sometimes have to ask for this type of repair. Most tire repair place would either use a simple plug or patch method.
http://www.tireservicecentral.com/Pr...hemicals_5.htm
Chu..
Old 02-27-05, 01:02 PM
RA40
Super Moderator
RA40's Avatar
Ah...interesting, thanks.
The shop that fixed it looks to have used a plug. So far, it seems fine.
Old 02-28-05, 10:45 PM
mikeyboy
mikeyboy's Avatar
plugs are perfect, will definitly last the life of the tire without a problem.
Old 02-28-05, 11:49 PM
RA40
Super Moderator
RA40's Avatar
Thanks!
Of course this happens with a newish set of rubber...less that 3K on them.
Old 03-01-05, 02:10 AM
ChuH
ChuH's Avatar
Sorry but I have to disagree with you on PLUGS are perfect. Everything I read plugs are improper repair method. Best method is still mushroom shaped plug-patch method. For more information please check out the following links.
http://www.tirerack.com/tires/tirete.../punctures.jsp
http://www.michelinman.com/mastapp/s...t&pclass=2&p=4
http://www.dunloptire.com/care/tireRepair.html
http://www.coopertire.com/us/en/safe...ons.asp#item12
Chu...
Old 03-01-05, 10:52 AM
damon
damon's Avatar
I agree with Chu.
How is it possible that a purpose made product combining the best of of the plug & patch is not the best method?
Saw this new fix at the Discount Tire last time I gor a flat fixed. No longer free there, btw.
Old 03-03-05, 01:03 AM
Lexusfreak
Lexusfreak's Avatar
Wink
Just courious RA, was the nail in the front or rear tire? About 80% of all flats (caused by a nail or other debris on the road) is in the back tire........as the front tire 'skips' the object up causing it to imbed into the rear tire.
nathantse
09-05-18 09:39 PM
niteflite
08-22-09 11:02 AM
1993ES300x
26
04-13-09 07:53 AM
O. L. T.
07-02-08 07:34 PM
markyboy
03-28-08 09:14 PM
Quick Reply: Patch or plugs to repair a puncture?
