17" front and 18" rear?
Originally Posted by Neo
What tire size are you planning to use? Are you going for a larger diameter overall in the rear?
I'd like an agressive stance on the SC
i've got 19 front 20 rear..
no issues from i've researched/experienced.
here is a pic of 19 front 20 rear.. i think its Ueno's one of seven soarers if i'm not mistaken?
Originally Posted by Goldark
Yes
The One
Originally Posted by 1993SCTT
i have a sidewall of 40 on a 19" rim up front
and a sidewall of 30 on a 20" rim for the rear
which is really the same as what was stated above ^
I guess it is just the SC body style that makes a 20" rear 19" front look balanced. Take a look at this photo (I hope J4Dint doesn't mind). He's got 20" all around. By looking at the photo pictured below, doesn't it create the illusion that the front wheel is larger than the rear? Now I know this is because his car is a tad bit higher up front than it is in the rear, but since it is impractical to lower anymore in the front (unless you've got air-ride), it will create the illusion of a larger wheel up front than in the rear. Follow the body line of the SC, the fender cutouts are larger front than rear, so this is my reasoning for going a 19" front 20" rear, to create a more balanced appearance.. so really they will both look like 19s. My front will be slammed as far is it can go, without it being tucked, but since my rear wheels are stationary and not turning, I will tuck them about half an inch. Will post pics once wheels are mounted.
