View Poll Results: Should I fix this or get new rims?
Fix it!
37.50%
Get new rims!
62.50%
Voters: 8. You may not vote on this poll
Is this damage fixable?
So I had a slow leak which I thought ws from the tire, but I found out today that my rim is cracked...is this even fixable?
So I guess the question is:
1. Should I fix it, re-apply clear coat and have it look brand new? (By the way, I think two of the rims are slightly bent, too)
2. Or should I just save up, put on the stock rims, and get new rims?
See attached pics! Thanks for the input...
Any good wheel shop can repair that crack in 48 hours with a cost of about $125... That's a very common crack that happens when hitting pot holes at higher speeds. Good luck
I figure....if I'm going to get this fixed, I might as well bring all four rims and have them re-polish all four, take out the slight bends (if there are any), and then just have them as "brand new" to me again.
Heck, I'm saving up for the new Eclipse line, am getting married, and am looking to purchase a home. I don't think I can swing for a new set of rims yet....especially since I want a big brake kit next!
Does anyone know how much it costs to fix road rash and unbend rims (very slight)?
I think I might have to do that this week....
Originally Posted by 1993SCTT
How did you notice the crack? Were you leaking air?
For the next couple weeks, I'd be filling it up yada yada yada. I finally broke down and brought the wheel in to a tire shop to fix the "leak". They later told me that my rim was cracked.
When I went in to see it, I wasn't shocked, but I was a bit surprised as I'm pretty "with-it" when I'm driving and am always looking out for potholes.
Once repaired it will be good and seal good as before. The rim repair shops will aluminum weld it, then grind it smooth and polish it to match if needed. When my old rim cracked like that, a friend of mine took it to some of his friends at the local community collage and the students welded it. Obviously in my case they keept the weld bead and did not grind it smooth, but the tire still balanced out and it never leaked. Cost to me was free. For the students they got to practice their skills. Anyway, unless you want new rims just get it repaired.
Originally Posted by Din
what kind of rims are those?
look to spend about 125$+ per wheel to get them all refinshed.
I talked to a buddy of mine yesterday who referred me to a good place and said that they'll probably charge me $85 to weld the crack, but he wasn't sure how much it would cost to refinish each wheel. I'll most likely find out today.
The thing that stinks is that they're a modest drive away...I'm almost tempted to ship it to them.
