235/30/19 or 245/30/19
i know they make them! but i can't find them!
i need to buy smaller tires up front for my SC because the ones that came on my 19" rims are too big.
what would you guys recommend for a 19x9 rim on an SC up front? i can't run the current 245/40/19 with a slam because i'm afraid of rubbing..
what tire size would you recommend for these 19s on an SC so I can work my slam without rubbing?
i've got the tein flex installed but would like to lower the coil some more
i can run my 245-40-19, but i can't lower as much as i want without rubbing
how low did you go with the 245 35 19?
im not too sure about the offset, no stamped on inside.. but i can approximate 42
they just come out to the fender.. right under the fender lip, not past the fender, not sunken.. but i need to roll the fronts.
thanks for the help.. and when you say "you've been there and done that", does that mean you aren't doing it anymore? did you sell your SC? or you were just saying? just curious,thx
19" wheels without rubbing
Originally Posted by stevechumo
I recommend you use 245/40/18 for the front and 255/40/18 for the rear. This is the best setup for your car, which you can still see the car and not just the rims. I've been lowering for many cars now so that's what i thought. However, if you intended using 19", you may cut the inner fender edge and paint that edge with black paint. Also, masking tape is a must around the edge from the outside to prevent miss spray and be careful not to make dents on the fenders' outside. That way, you can add about 1" more without rubbing the precious tires. These are what I did
Johnee78, yeah I will probably end up getting 245/35/19 for the front, since that seems to be lowest sidewall I can find. Also, I sent you a private message. Thanks
19" rims
I cannot use your recommendation for my rims. You are giving my tire sizes for 18" rims.. I have 19" rims. And I cannot use 245/40/19.. b/c thats what i've got now and i'm rubbing.. I will probably end up getting 245/35/19, but would buy 245/30/19 if I could find them because I am going SLAM . I have 285/30/20 in the rear and just hat to shave the fender lip to make them fit.. and I can run my slam with no problem.. just the front needs smaller tires, and I haven't shaved the front lip yet since that is the only thing getting in the way.
i run 19*8.5 wheels on 245/35/19 and i have no rubbing in the front
in the rear i have 19*9.5 with 275/30/19 and they are just fine
i like the way they look
good luck with yours
mikemareen
07-30-07 09:15 AM
