19" GS Phat Tire Setup
Old 02-02-05, 04:07 PM
CaMsGS3
CaMsGS3's Avatar
Default 19" GS Fat Tire Setup
Will a 275/40 Tire fit in the rear?
Im thinking about going with 245/40 F & 275/40 R - is this possible
Oh yea I have about a 1.2in drop
Thanks
Old 02-02-05, 04:49 PM
Neo
The One
Neo's Avatar
Wow. That rear is 2" over OEM and 1" bigger than the front. It might fit in the wheel well with the 1.2" drop and you won't have the "turning" rub like the front. Other rubbing will depend on offset.
Still, I am not sure what would happen if you ran a wheel that much bigger than OEM in addition to different diameter wheels front and rear. It is already bad enough that the typical fat setup is 1" over OEM all around.
Any particular reason for doing this?
Old 02-02-05, 04:54 PM
CaMsGS3
CaMsGS3's Avatar
thanks - na no reason was just thinking out loud
I figure the ride would be alot better with a 40 series tire, i guess ill stick to the normal fat setup - 245/40F, 275/35R
Old 02-02-05, 08:49 PM
rominl
exclusive matchup
rominl's Avatar
the 245/40 and the 275/35 have the same amount of sidewall front and back.... 275/40 wil have more sidewall in the back than the front actually
and personally i think you feel more of the front from the front
Brokenis
06-23-22 01:55 PM
LTU-Lexus
08-22-09 08:11 PM
L3XUSGS400
04-19-06 09:59 PM
RRocket
03-02-05 09:21 PM
SinisterSC
07-31-03 01:54 PM
Quick Reply: 19" GS Phat Tire Setup
