Can G35 and 350z lugs pattern fit GS400?
Old 01-30-05, 09:11 PM
Gs L-tune
Gs L-tune's Avatar
Default Can G35 and 350z lugs pattern fit GS400?
Does anyone know can the G35 or 350z lugs pattern fit Lexus GS400?
Old 01-30-05, 09:45 PM
Neo
The One
Neo's Avatar
I believe so as wheels are sold interchangeably with the G35s and the GS. The only thing to watch out for is offset as the G35 can take lower offsets than the GS can.
Old 01-30-05, 11:08 PM
Gs L-tune
Gs L-tune's Avatar
Thx Neo this question pretty stupid but yeah can you help me with it. How can i tell which offset is right for my car? My car about 1.5 drop can i fit the offset 15front and 20rear
Old 01-30-05, 11:49 PM
400DGRZ
400DGRZ's Avatar
No. Offsets are way too low.
Old 01-31-05, 12:19 AM
rominl
exclusive matchup
rominl's Avatar
well it will depends on the width too, offset means nothing without the widths
but in general, if you are talking about g35 coupe, then if it's a good set of wheels that fit the g35 nicely, it will more than likely NOT fit the gs, coz' the gs can't take that low of an offset with the same width.
Old 01-31-05, 01:47 AM
Neo
The One
Neo's Avatar
Totally agree. G35s can fit nice low offsets with deep lips while the GS can only dream of fitting those.
Assuming the G35 was setup optimally, unless you are planning to do flares or doing fender mods and some neg camber, I'd stay away. Even with doing the latter, it will be a marginal fit.
Bottom line, look at another set of wheels.
Old 01-31-05, 02:23 AM
rominl
exclusive matchup
rominl's Avatar
from the very few offset numbers i have seen, the g35 coupe seems to fall in line more with the sc430 fitment
Old 01-31-05, 05:01 PM
Cannonbear
Cannonbear's Avatar
even the g35 stock rims won't fit?
Old 01-31-05, 05:07 PM
Gojirra99
Super Moderator
Gojirra99's Avatar
Offsets of the HRE's on my G35 coupe are front 17, rear 31, wouldn't you say that's still too low for the SC430 ?
Old 01-31-05, 05:34 PM
TRULUX
TRULUX's Avatar
yes i took off my wheel on my gs300. alba bertha series wheels. dont know the offset but i put them on my wifes g35 sedan they are kumo 245/40 zr18. i have not had any problem with them rubbing at all. the wheels went on perfect. so my answer is yes.
Old 01-31-05, 05:48 PM
dagr8tsthustla
dagr8tsthustla's Avatar
First off.....What model G35??? If it is the one with the Brembo Brake package then no....it will more then likely not fit....if it is the non-Brembo package then yes it should fit....second....which rims are they and what widths???
Old 01-31-05, 05:59 PM
TRULUX
TRULUX's Avatar
Alba Bertha series wheels 18/8.5 . No Brembo. i took them off my car because they where way to heavy.
Old 01-31-05, 07:47 PM
Neo
The One
Neo's Avatar
Depending on the back spacing, going from GS to G35 is easier since the GS offsets are more conservative. Going the other way is the issue. (I am ignoring brake issue and am just looking at spacing fitment. )
I would imagine the wheels now sit more recessed in the G35 than on the GS making it look less aggressive than on the GS.
Old 01-31-05, 08:10 PM
LexFather
Guest
Posts: n/a
I know (how do I put this nicely) that G35 or 350Z rims don't belong on any Lexus. As LExus wheels do not belong on any Nissan.
Old 01-31-05, 08:41 PM
rominl
exclusive matchup
rominl's Avatar
that's 8.5 and 10? if so, then i think it will fit. there are actually still room in the back for the sc430
Quick Reply: Can G35 and 350z lugs pattern fit GS400?
