Weight of factory 18" LS430 wheels
Old 01-20-05, 04:15 PM
Smoothride
Smoothride's Avatar
Question Weight of factory 18" LS430 wheels
Can anybody tell me the weight of factory 18" LS430 wheels. I'm looking to upgrade my wheels and know that wheel weight affects ride quality, I want to use the weight of the factory wheel as a benchmark. Accurate replys please, no guessing.
Thanks all...
Old 01-20-05, 09:46 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
i don't know 100%, but judgnig from the weight of the stock gs 17s being 25lb (just the rim), i say the 18s would be beween 26 to at most 28lb?
Old 01-21-05, 12:28 PM
Smoothride
Smoothride's Avatar
Default Thanks
Thanks ronimL,
that's kinda heavy, I was hoping that someone has a rim w/o tire and a scale to weigh it. What I might have to do is weigh my spare and then find out how much the tire weighs from one of the tire website and then do the math.
Old 01-21-05, 02:23 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
i thought around 25lb that's pretty "standard" for oem wheels?
Old 01-21-05, 04:23 PM
Smoothride
Smoothride's Avatar
Default Hmmm
Well, I have a Miata and Miata folks are REALLY **** about wheel weight. A lightweightwheel will wiegh about 1 pound per inch up to about 18" or so. Now the Lexus dish type might be heavier to get the strength needed from that particular style. Cheap wheels are generally heavier because of less CAD/CAM time, attention to detail and not being forged . The 15" on my Miata are 12 lbs and alot of those people go for 15's that weight under 10lbs.
I'm hoping to find something that weighs less than the factory 17's or 18's in a style that I like.
Old 01-21-05, 05:14 PM
DaveGS4
Forum Administrator
Administrator
DaveGS4's Avatar
Received 2,312 Likes on 1,410 Posts
Smoothride,
I think you're going to find that the much heavier Lexus cars require a heavier wheel. I'm sure you're familiar with sites like
http://www.wheelweights.net/
that will give you some info. It's hard to find a good balance of lightweight wheel that will stand up to potholes with a heavy car like the LS without bending. Some lighter wheels that some of our members have are SSR Competitions and Volk TE-37. Neither of these IMO go well with the style of the LS.
Old 01-21-05, 05:30 PM
Smoothride
Smoothride's Avatar
Thanks Dave,
I was assuming that the manufacturer took into consideration the intended market by using wheel size, bolt pattern and offset, therefore making the wheel strong enough to take real world driving on a LS or Mercedes or whatever. I have seen the wheelweights site before, but I think it isn't really up to date and have all the high line wheels. I just need to find what I like at reasonable price at a reasonable weigh, not asking too much, am I? ;
Old 01-21-05, 05:44 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
if you are getting 18s or 19s, and wide setup say around 8.5 or even 9 3 piece, then i think 25lb would be consider pretty light. if you get one piece you might get it lighter to around 24lb?
there are some very light 18s or so, like the te37, but those are very sporty and i think they would look horrible on the ls430. it's a vip car so it takes different wheels.
Old 01-21-05, 06:56 PM
RA40
Super Moderator
RA40's Avatar
Just as some additional FYI.
Yesterday I weighed the stock 16's from my LS and it comes in at 21 pounds give take a bit for the accuracy of my scale. The Michelin MX4V mounted on the wheel is comes in at 48.XX pounds.
The LSportline M4 one pieces with tire weighs in at 52 pounds. My call to BFG about tire weight of the 245/40-18 TA-KDW-2 was 26.28 pounds.
Old 01-24-05, 03:50 PM
DXC
DXC's Avatar
Then our 19" 2-pc wheels = 18" OEM weight Thanks for the info
Old 01-24-05, 08:54 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
my hre 20s have the same weight too, not too shabby
seriously, aftermarket wheels look big, but they can be light too, that's why they are worth the money
Old 01-25-05, 09:28 AM
DXC
DXC's Avatar
A lot of people say that upgrade OEM to bigger wheels will affect performance, now I can say AT LEAST weightwise, there shouldn't be any difference Thanks rominl, really good info
Old 01-25-05, 09:44 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
yup that's true. bigger wheel doesn't mean more weight, in fact if you pay good money you get less weight. however, of course, that's not the end of the story. coz' bigger wheels the tires are heavier, and also with bigger wheels, it depends on the design, and you might get more weight towards the outside of the wheel, which contributes to the unsprung weight. now that's costly
Old 01-26-05, 01:11 PM
DXC
DXC's Avatar
icic very detailed analysis
Old 01-26-05, 06:50 PM
Smoothride
Smoothride's Avatar
Default Hmmm
rominl,
You are about 1/2 right. As far as unsprung weight goes, it doesen't matter where the greatest part of the mass of the wheel/tire combo is. For unsprung weight, 50lbs is 50lbs. BUT, for acceleration, the distribution of the mass does matter. Acceleration will be affected by mass distribution. Since you are accelerating the wheel in a rotational direction, one would want the mass as close to the center of the wheel as possible for best acceleration.
Quick Reply: Weight of factory 18" LS430 wheels
