will i rub with 275x35x20.....
just wondering if anybody can tell me if i would rub by putting on 275x35x20 in the rear instead of 30series? i will be on a 1 inch drop provided by l-tuned shocks and springs. thinking maybe i might need some more tire. streets in downtown l.a. are not that great.....thanks, suxel
it looks fine w/ a 1 inch drop but probably the most important factor is the offset of your wheels to be able to tell if you will rub.... oh and this is in the wrong forum.
exclusive matchup
yeah it also depends on offset. but if 275/30 fits on no problem right now, i have a feeling that 35 will fit no problem too
however, the more serious problem is that your overall diameter would be way way way out of spec from stock.
and don't even think about putting 245/40/20 in the front, that will NOT work
exclusive matchup
Originally posted by Neo
275/35/20? Wow, if you are using the 17" spec of 235/45, that is about 2.3" bigger than spec. You are the anti-VIP. Instead of lowering the spec and stretching, you are increasing the size.
