L-tuned & rims
Old 10-29-04, 02:05 PM
slawek65
slawek65's Avatar
Default L-tuned & rims
Any of You guys with GS and L-tuned susp. What size rims, offset and tires size You have on Your's car? Thank You.
Old 10-29-04, 02:21 PM
Neo
The One
Neo's Avatar
What are you trying to determine? At one point, I had the L-Tuned shocks and springs with L-Tuned OZ Salinas rims. They were 18x8f and 18.9.5r, +45 offset all around. Tires were 235/40f and 265/35r.
Old 10-29-04, 02:29 PM
slawek65
slawek65's Avatar
I just want to know if I can run 18x8 rims with 245/40/18 tires with +35 offset with out rubbing.
Old 10-29-04, 02:37 PM
Neo
The One
Neo's Avatar
All around? You should be fine.
Old 10-29-04, 02:40 PM
slawek65
slawek65's Avatar
I ask this once and I have YES and NO ansvers, so I am asking people who have this set up right now. Tx.
Old 10-29-04, 02:54 PM
Neo
The One
Neo's Avatar
Sure, the more data points the better. To compare, to the L-Tuned I had, your wheels would be more agressive in the fronts by 10mm. I have 20x8.5 +43 now. This is like x8 with +37 so it is not far from yours. rominl is running x8.5 +32 so it is ike x8 +26. You are well within the range. I have some rubbing but it has more to do with the extra 1" in wheel diameter.
As for the rear, the L-tuned (x9.5 +45) would be like x8 +27. As you can see, the rears will be no problem.
These calculations are approximate but it should give you an idea.
Old 10-30-04, 10:38 AM
slawek65
slawek65's Avatar
Thank You Neo, but can some of You who have this set up (18x8 +35 245/ 40 18 ) on Your's car rignt now let me know if this no rubbing.
alexus
Wheels and Tires Classifieds
20
06-24-09 06:42 PM
alexus
03-15-09 04:34 PM
etnarp
03-24-05 01:24 PM
kyle3481
04-24-04 02:18 PM
Quick Reply: L-tuned & rims
