rim info
rim info
i have my mind on some new shoes for the SC3, and im lookin for 18 X 8's or 18 X 8.5's. i have no clue about bolt pattern or tire size and offsets. my car also has a 1.5inch drop. what size should i be looking for that will fit my car? thanks
your bolt pattern should be 5x114.3, on an 8.5, you can have a +45 offset all around and run a 235-40 size tire......wheel experts, correct me if im wrong......but my old set up was 18x8.5 all around aith a +45 offs and 235-40 tires, just speaking from experience
exclusive matchup
Originally posted by nysupraman
thanks but if i go with 18 x 8's what offset and tire should i use? and also do i have to specify offset when installing the wheel or when buying it?
and if you use what i said, 8.5 +38 as reference, then the corresponding 8 would have a offset of +32. this is to have the same flush with fender
celm
Wheels, Tires & Brakes Forum
12-14-12 03:41 PM
istundra
02-14-09 07:36 PM
