Supra TT brakes w/38 offset on my SC?
Super Moderator
Location: Sideways on the Yellow Brick Road! < Thats KS!
OK I know this topic has been beat to death in the forum and yes I tried the search buttons but I still am unsure. I want to put the Supra TT brakes on my 97 sc400 and I need to know if they will fit. I recently purchased some 18” wheels with an offset of 38 mm.
Here is the thread to what wheels I ended up with.
https://www.clublexus.com/forums/sho...hreadid=128837
Does anyone know if they will fit?
Is there some measurement I could take with the wheels installed to verify they will fit?
I’m trying to close a deal on some Brakes but need to know before I get myself into a bad situation.
Re: Supra TT brakes w/38 offset on my SC?
As for if they will work with the wheels you purchased, the question you need to be asking is are the wheels 'high disk" or "low disk". You will need high disk wheels to clear the Supra TT calipers. Use the 'search' button to gain an understanding of what 'high disk' is as it's not the easiest thing to explain.
If your wheels are Supra TT fitment wheels, you shoudn't have any problems. If not, you'd better check. If you know anyone with a Supra TT that you could test fit your wheel on, that would answer the question as well.
Good luck....
Nguyenrrr
Suspension and Brakes
02-28-13 04:44 PM
Nosexnolex
Wheels, Tires & Brakes Forum
01-03-08 06:26 AM
Slow_go_400
01-19-04 03:52 PM
