Possible Stupid Question.....
Old 09-02-04, 01:51 PM
TwentyTen
TwentyTen's Avatar
Default Possible Stupid Question.....
I've search the net but couldn't find the answer....
okay..........
here it goes................
What keeps the tire on the rim???
I just cant figure it out.
Any and all comments welcome. Feel free to bag on me - I just CANT find the answer
Old 09-02-04, 01:53 PM
C to the O
C to the O's Avatar
I'm kinda curious to find out as well...
All I know of the process is that machine that takes the tire off the wheel, or vice versa.
Old 09-03-04, 01:24 AM
rominl
exclusive matchup
rominl's Avatar
umm good question, i don't knnow the 100% answer too. i have seen tire mounting close to a trillion times. from what i see, it's already a lot of force just to stretch out the tires to fit over the rim, so i believe the stretching alone would hold the tire in place already. and also, before they put the tire on, they put some stuff (liquid) on the two edges of the inside tire. i suppose those are glue type stuff coz' sometimes after install i see some leftover on the rim that i can rub off easy
Old 09-03-04, 05:26 AM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
Default Hrmm
The bead seat of the wheel keeps the tire on the rim. If you look at a bare wheel you will see 2 ridges on either side of the barrel section. The beads of the tires fit into the bead seat and then under the pressure of the air the bead section of the tire "pops" into a secure place on the bead seat. The liguid Romi sees is a lubricant that does dry a bit chalky.
Old 09-03-04, 08:43 AM
TwentyTen
TwentyTen's Avatar
Thanks Brandon. So the tirew starts off just a " little" too small, then is stretched over the rim. A combination of the stretching, air pressure and bead seat keep the tire on the rim.
Ohhh, okay, I've got it. Now I can sleep ;p
Old 09-03-04, 11:29 AM
DVSG3
DVSG3's Avatar
The only liquid I have seen used is a soap and water mixture. Slick when wet and tacky when dry.
Old 09-16-04, 10:53 PM
rominl
exclusive matchup
rominl's Avatar
Default Re: Hrmm
oh so that's lub not glue yeah it dries up very chalky, i always have to rub them off
Yesterday
SC- 1st Gen (1992-2000)
01-20-11 12:25 PM
IS_Sunny
11-15-07 09:35 AM
black_LS
10-13-07 02:02 AM
alexus
12-08-04 02:06 PM
e-man
11-11-04 04:00 PM
Quick Reply: Possible Stupid Question.....
