Volk GTU w/ Supra Fitment???
Old 08-30-04, 04:34 PM
prjctSC300
prjctSC300's Avatar
Default volk gtu w/ supra fitament???
i thinking about buyin a set of volks gtu and the size are 18x9 with a +37 front and rear is 18x10 with a +44 offset. will these fit my 92 sc300 lowered wih tein HA's, what tire size to go with?? thanks
Old 08-30-04, 05:06 PM
legendary
legendary's Avatar
They should fit your car just fine
Fronts: 245/40/18
Rears: 275/35/18
Edit, there might be slight rubbing - but if it is not camber corrected it more than likely will be fine.
Post pics when done
Old 08-30-04, 05:23 PM
prjctSC300
prjctSC300's Avatar
how much camber do i need?? or can i just roll the fenders??
Old 08-30-04, 05:34 PM
legendary
legendary's Avatar
you dont necessarily want neg camber.Get them on the car, get an alignment and go from there.
How much have you lowered the car?
Old 08-30-04, 05:40 PM
prjctSC300
prjctSC300's Avatar
i have about a 1finger gap all around, not too low. will i be able to fit 285's in the rear??
Old 08-30-04, 07:05 PM
quikturbo
quikturbo's Avatar
I have that setup on my car and I run 285's on back. My car is lowered with eibach's and agx's so I'm probably not as low as you. I get a tiny amount of rubbing on a large bump or under a hard launch.
You'll probably want to roll the fenders and you'll be fine.
Chris
Old 08-30-04, 07:10 PM
prjctSC300
prjctSC300's Avatar
you got any pics, i just want to see how flush the rear wheel sit under the fender well, thanks
Old 08-30-04, 08:46 PM
quikturbo
quikturbo's Avatar
Here is the only one I found
Old 08-31-04, 10:56 PM
prjctSC300
prjctSC300's Avatar
whats your wheel specs? offset??
Old 09-01-04, 01:08 AM
rominl
exclusive matchup
rominl's Avatar
personally i don't see why it won't fit? i have 8.5 32 front and 10 43 rear on my gs4, and i know the sc has a bit more room to go
Old 09-01-04, 04:52 AM
quikturbo
quikturbo's Avatar
Volk GTU's
18x9 37mm offset
18x10 44mm offset
Here is my thread back when I got them on.
https://www.clublexus.com/forums/sho...ghlight=wheels
Old 09-01-04, 07:47 AM
prjctSC300
prjctSC300's Avatar
quik: did you have to roll your fenders at all?? did you eventuallly lower the car?? what size tires are you running in the front??
Old 09-01-04, 08:22 AM
quikturbo
quikturbo's Avatar
I haven't rolled the yet, but I'll be doing that soon.
Tires:
Birdgestone S03's
255/35/18
285/30/18
dfwjohnd
05-05-14 06:11 AM
laxton
IS - 1st Gen (2001-2005)
02-08-13 02:40 AM
lextac
09-14-09 12:05 AM
RedPhoenix
SC- 1st Gen (1992-2000)
13
08-01-08 10:39 PM
Yeah!
09-29-07 09:55 AM
Quick Reply: Volk GTU w/ Supra Fitment???
