Supra Brakes 96 Ls 400
Here is a question. I took my 96 ls400 to the shop the other day, because I started to hear grinding and I looked and my back right rotor was cut like someone took a chain saw to it. So they threw it up on the lift - 45 minutes later they told me that I have four (4) count them four (4) seized calipers. and both my back rotors would need to be replaced. $1200 worth of brake damage. Has anyone heard of that. I know 1 caliper might stick, but four. I told them that that was too much for me to fix right know, so purchased a set of cross drilled /slotted rotors off of ebay. I know they aren't the real deal. But for $239 - I can deal with that for now. As far as the calipers go, I want to replace all of them. I have found a pair of Supra calipers, but I don't know if they are the ones that everyone is talking about upgrading too. I am enclosing a picture. Are these the calipers? Let me know. Also I still have stock 16 oem - will the supra calipers fit or do I have to get bigger wheels. I do have a set of 19" illan Cezzanie rims, but I haven't bought new tires for them yet, so I want to put those on next year. What are my options
Super Moderator
You can have your calipers rebuilt. If they have seized, the instances I've had were due to excessive build-up of brake dust around the piston causing it to bind. Extend the piston clean the grime out and see if they function again.
I dunno if the TT Supra calipers bolt up...it is possible. You may give TM Engineering a call or drop him a PM about this. Doublewoosh or doublewoosh.
Word of caution which you've probably read about the drilled rotors...they have a tendancy to warp with stock caliper set-ups.
fiveohfour
General Classifieds
04-14-09 09:26 AM
WICKED SC4
Suspension and Brakes
51
12-09-07 11:50 AM
luciano
05-24-06 07:12 PM
