questions about rotors and pads
i just got an inspection, but i failed because of rotors and pads.
i also need to get new tires as well( they said).
where can i get some cheap but good rotors, pads, and tires?
these problems are driving me crazy.
If it's surprising to you that all these minor things need replacing then your problem is either:
1. they're seriously screwing with you for no apparent reason or...
2. your car is POORLY maintained.
In either case you can solve the problems easily...man you have a Lexus, don't go around looking for the cheapest parts you can find. Get the CORRECT parts and hunt around for deals in your price range
Originally posted by aliga
i think its number 1.
Former Sponsor
let me tell you this story, one of my brother's auto mechanics used to work as a service writer for a lincoln.
one day his boss told him that he has to writeup more repairs (meaning he has to tell the customers that alot of other things are broken on the car, so they can raise the repair costs). He told the boss that he would not rip customers off, and soon after he got laid off on some bs.
He told me this happens everywhere! So be careful, do not get scammed.
thanx for the replies, but when i step on the brake pedal the steering shakes and the red brake light on the board shows.
i took it to lexus dealer first to get an inspection but they are the ones who told me the rotors and the pads need to be changed so i don't think it's #1.
plus, if a/c doesn't work, then what's the problem?
the air comes out but the cold air doesn't come out.
perhaps your ac needs to be recharged. But that might not help if its leaking. but either way u should have a ac place refill it and add the special dye to it so if it does leak out you'll know where.
i found this site, and i wanna know if these are the good parts with good prices to replace my rotors and pads.
http://www.importrp.com/catalog.php?...s&subcat_id=10
dat's for the pads.
http://www.importrp.com/catalog.php?...s&subcat_id=11
and dat's for the rotors.
please take a look at them and tell me.
dat's for the pads.
If, and only if I can get you wagner brake pads and some rotors for cost.
just PM me the year and I can check.
The same goes for everybody.
I can get Toyota/Lexus parts at dealer cost because I have the hook up now....
Josh
Josh
those are pretty good prices compaed to what the dealer would probably end up charging you
if the mechanic can see threw the spokes of the wheel....he can tell how thick the remaining pad material is......most pads are actually made to squeel like hell when they come close to need to be changed...reason is because they want you to go to get them looked at...average person doesn't think about servicing their brakes.....
the reason the car might shake(most common reason) is because the rotors might need to be resurfaced.....when they grind down the contact surface to make it smooth again....this is cheaper then replacing the rotors....
but they might be able to tell you that the rotor cannot be resurfaced...and then you gotta buy new ones and pay to install them
if you do buy rotors....i would recommend to stay with blank rotors(as pictured in the link)...cause alot of aftermarket slotted/drilled rotors are low quality....and most solid OEM replacement rotors are OEM quality
