RE: Rear Fenders Rolled ??
Most of you that are running a 20x10 rear wheel with a 35 offset or higher, do you have to roll the fenders and does that take care of the problem?? Thanks
What kind of car are we talking about? For the GS, you will have to shave down the metal inside the fender so you don't rub. I have a +39 offset and I was rubbing the sides of my tire before I shaved the metal. But I was also lowered on coilovers.
The One
Re: RE: Rear Fenders Rolled ??
exclusive matchup
Re: Re: RE: Rear Fenders Rolled ??
Originally posted by Neo
I think you mean 35 or lower right? I believe rominl has +42 in the rear and I think he did not rub although he shaved the fenders anyway. I can't remember the exact point where you start to rub but it is obviously between 39 and 42. Haha. At +39 like LXOGOOD, shaving about 5mm is a safe amount. With even lower offsets, you are starting to look at shaving off that whole tab in the fender. It also depends on how low you are planning to drop the rear.
yes, if your offset if 42 or higher, with the right tires you won't rub and no need to do anything. anything less than that you need to start shaving the fender
if you have 35, you will have to shave the whole fender
The One
Re: Re: Re: RE: Rear Fenders Rolled ??
Originally posted by rominl
no, 42 is higher than 35, so that's 35 or HIGHER yes, offset goes like that, a lot of thinking
Master Thread Closer!!
Originally posted by jtanoyo1
I run 19x10 +24 in the back with no fender rolling but very aggressive camber, with no rubbing. But of coz no one here believes me....
