20x11 on a gs400
20x11 on a gs400
lowenhart ld1's 20x9 (32 offset) front 20 x 11 (37 offset) rear anyone think its possible with mean camber and rolled fenders and stretched tires. i talked to dazz directly and they said it will work. any opinions? i am kind of questionable about this myself
20x9 +32 offset / 20x11 +37. Are you kidding? Good luck bro. If you plan on lowering your car, you will rub like crazy! That setup is way too aggressive for a daily driver.
Former Sponsor
Originally posted by LXOGOOD
20x9 +32 offset / 20x11 +37. That setup is way too aggressive for a daily driver.
I know that member SoCalSC4 was researching a 11" fittiment for his car, perhaps he can chime in and offser some insight/advice.
My new wheel setup in the rear is a 20x10" +39 offset and I had to shave the inside of the fender so i wouldn't rub the side of my new tires. 20x11 +37 will make the wheel stick out pretty far so you would need to do a body flare to keep it looking right. I would avoid this setup....
Master Thread Closer!!
Well....if you are staying at stock height (no drop)...you should be able to fit it....albeit this setup will stick out past the fenders. You will probably rub when driving it cuz the stock suspension is bouncy.
Pete
Pete
exclusive matchup
Originally posted by DGOT20s
I agree, this setup is aggressive from all angles. Wheel width and offset. I am running a 10" with a 42offset I rub occasionally (when I have the rear passenger side really loaded). You would have to do ALOT of fender modding (possibly flare) to fit this combo.
Former Sponsor
Originally posted by rominl
pretty surprising. i have 10 +43 and i never rub
exclusive matchup
Yeah I have the Nitto 555 which has a very square sidewall design, also I only have an occasional rub if I have someone of considerable size back there, like 200lbs plus, which is not often. I think I have rubbed 1-3times thats about it.
Former Sponsor
interesting, my nero is very sq too. maybe you can just go ahead and shave down the fender tab a little bit? that's what i did just to be safe, even though i never rubbed
exclusive matchup
Yeah I guess, I have yet to do any fender rolling front or rear, I did remove black fender guard in the front though. I must have pulled that thing down 4 times in 2 weeks!
Former Sponsor
gotta learn how to drive man actually in the front, at around the 10 oclock and 1 oclock position you should see two pretty big tab. i push them all the way up, that helps a lot
Former Sponsor
Originally posted by Neo
You cut them off? really?
I take driveway entrances at somewhere between 0.00 and 0.05mph
