Rim Question-Pt. 2.....Help!! Any One
Old 07-06-04, 08:18 PM
Alexus-Kia
Alexus-Kia's Avatar
Default Rim Question-Pt. 2.....Help!! Any One
Question about these damn wheels again!
This is what the dude said about the wheels i want
Tire Guy:
Your car is RWD but requires a FWD offset.
I can get you into a 245 for a little more but I have done a few of those cars before and the 255-35-20 works perfectly. There is only 1/4" difference and will provide a better ride. I do have them in a Falken Fk451 which does have a smaller section width than the Goodyear and the tire I would use if it were my car. I can sub these at no extra charge.
so what do you think....should i get 245's w/38mm offset or should i test the 255's?
To make a long story short 2 Questions:
1) What offset is best +35mm Offset or +38mm Offset
2)And tire size 245's or 255's
Thanks
(Please no opinions on what you think of the wheel)
Here is the first post of this question:
https://www.clublexus.com/forums/sho...5&pagenumber=2
Old 07-06-04, 08:35 PM
rominl
exclusive matchup
rominl's Avatar
umm...... if i have to choose, 35 with 245. 38 and 255 should be ok too. 35 with 255, i would be careful
Old 07-06-04, 08:54 PM
Alexus-Kia
Alexus-Kia's Avatar
ok.....
i need more opinions so i can get a solid answer of what i need to do, i will get more answers and then go from there!
Thanks rominl
Old 07-06-04, 09:01 PM
Neo
The One
Neo's Avatar
Originally posted by Alexus-Kia
ok.....
I agree with rominl.
Old 07-06-04, 09:02 PM
johnee78
johnee78's Avatar
Exclamation
Do the +38 and 245...It will not rub and if it does it will only be when your wheels is fully turned..Is the wheel a 20x8.5??
Old 07-06-04, 09:44 PM
Alexus-Kia
Alexus-Kia's Avatar
wheels: 20x8.5
Bolt Pattern: 5x114.3mm aka 5x4.5 and 5x112mm
Offset: +35mm or +38mm FWD ( i know my car is RWD was told i can still fit these wheels)
Thanks Again!
Old 07-07-04, 07:36 AM
johnee78
johnee78's Avatar
wheels: 20x8.5
Thanks Again!
Definately go with the +38 and 245..the 255 in the front is too big and the +35 will scrub..
Old 07-08-04, 11:02 PM
Alexus-Kia
Alexus-Kia's Avatar
Hey guys.....
The guy said the wheels only come in a +35mm Offset.. (no +38mm)
SO......will i be ok to run the 245 tires w/ a 35mm offset and 20"x8.5 wheels???
Also did anyone ever hear of the nitto 225/35 tires .....are those Better to get or stick w/ the 245's??
Thanks
Old 07-09-04, 12:55 AM
Neo
The One
Neo's Avatar
Hey guys.....
Thanks
Stick with 245s. 225s are too narrow.
As for the +35 offset, it will still fit. Depending on how low the car is, though, you are in modding-the-fender area.
Old 07-09-04, 09:29 AM
Alexus-Kia
Alexus-Kia's Avatar
naw.. i'm not lowering and not planning to mod the fender area keeping everything stock w/ 20's!!
so i should be alset right!!
Thanks "Neo"
Aweera
12-10-22 01:50 PM
stlgrym3
04-05-17 10:33 AM
tures
06-02-13 03:47 PM
celm
12-14-12 03:41 PM
GS400drive
12-08-03 08:57 PM
Quick Reply: Rim Question-Pt. 2.....Help!! Any One
