uneven tire wear
Old 06-22-04, 07:45 PM
laxg0alie
laxg0alie's Avatar
Default uneven tire wear
I have a 1999 ES 300 and I noticed recently greater on the sidewalls of both the front and rear right side tires than on the left side. I'm not sure why the wear isn't actually on the tread, but rather high up on the sidewalls. Any advice?
Thank you.
Old 06-22-04, 10:52 PM
Lexusfreak
Lexusfreak's Avatar
Cool
Start with the most obvious things first & check all air pressure in all the tires. When was the last time you had your tires balanced & a 4 wheel alignment........don't forget to regularly rotate them. What kind of tires are on your car?
Old 06-26-04, 11:58 AM
AristoTDOT
AristoTDOT's Avatar
buy a camber kit....it worked for me
Caydoc
ES - 6th Gen (2013-2018)
03-04-19 03:54 PM
Bullskim
11-15-09 12:32 PM
blklexo818
Suspension and Brakes
50
10-22-08 02:54 PM
njmurvin
09-20-08 02:45 PM
autodriver
Maintenance
05-22-04 01:19 PM
Quick Reply: uneven tire wear
