How do you change the discs on a SC.
Old 06-08-04, 10:41 AM
W4SIM
W4SIM's Avatar
Default How do you change the discs on a SC.
Hi
Im not a mechanic by any means but i like to work on my car myself. I can usually do this when iv got the right info. Recently iv bought some Discs and Pads for my 1991 2.5 TT. I want to replace these myself but havnt quite got enough info to be able to do it properly.
I just basically want to know how the original brake discs are held on? Are they placed in the hub which requires a special tool to pull the whole hub out or are they just held on by screws? More importantly how do you get the brake discs off?
Also looking at the picture of these brake discs which way round are they supposed to go on, as in which way should the pattern be facing? This pic shows the front disc.
Many thanks in advance.
Old 06-08-04, 10:43 AM
mikeloc24
mikeloc24's Avatar
do a search for "brakes" and you should get a wealth of knowledge
Most topics we've covered at least 5 times so "search" should be your best friend...welcome to the club!
Old 06-08-04, 10:55 AM
W4SIM
W4SIM's Avatar
This is the rear disc.
Old 06-08-04, 11:49 AM
W4SIM
W4SIM's Avatar
Mike - Tried the search before i posted mate. Theres lots on about upgrades and what kinda upgrades there are out there but nothing on how you actually change the discs? Thats what i want to know?
Also it would be nice if some 1 pointed out which way the discs should spin?
Old 06-08-04, 12:28 PM
SC300Es
SC300Es's Avatar
Pictures page 3..
and 4
https://www.clublexus.com/forums/sho...5&pagenumber=2
Ed
Old 06-08-04, 02:33 PM
aasc300
aasc300's Avatar
Just remove the caliper moounting bolts and pull the caliper out of the way. Remove the mounting bolts for the caliper frame and pull it out of the way. Rotors should now pull off (if there are screws into the rotor, remove them with an impact screwdriver). If the rotor wont come off that easily, tap the rotor hat face (where the studs come through) with a hammer to loosen the rust holding them on. Installation is the reverse and the rears should be just as easy.
Old 06-08-04, 02:44 PM
W4SIM
W4SIM's Avatar
Ed
EXCELLENT stuff mate... EXACTLY what i was looking for. Much appreciated.
Looks like il be having some good braking abilities in the next few weekends.
Old 06-08-04, 02:51 PM
mikeloc24
mikeloc24's Avatar
Geezums! These guys are fast!!! Posted up your answer before I could find the darn link!! Oh well, there you go...good luck..oh, and drilled rotors ARE directional to answer your question. If you look at pics of people who have them you'll see what I mean. Happy braking!
LexBrett
10-16-15 06:40 AM
gdub686
Suspension and Brakes
09-01-12 05:37 PM
zojirushi
IS F (2008-2014)
12-08-10 08:58 PM
LexDriver19
SC- 1st Gen (1992-2000)
41
10-25-02 07:24 AM
Quick Reply: How do you change the discs on a SC.
