is it possible to run this
Former Sponsor
I dont know about the front, but I know someone that has a 20x10.5 on a GS and I dont think he has any issues
I would imagine the front would be prediacated on the offset and tire size, probably do-able though
Originally posted by lexforlife
245 35 front and 275 30 rear what would be a good offset to give a min of 3 in lip rear and 2 in front with high disk up front
19x9 High Disk with +36 to +38 will give u around 2-inch lip.
19x10.5 Super Low Disk with +45 to +48 will definitely get u 3-inch lip. But it also depends on the wheel model that u pick. Some wheels have huge lips and some don't.
exclusive matchup
actually, the offset doesn't really give you any information on how much lip you get. it depends more on the wheel design, spokes, etc....
if you wanna go MAX, i believe 9 in the front and 11 in the back is pretty much the max you can put on the 2nd gen GS. offset, i will keep that secret
and tires, with 9 and 11, you can put 255 in the front and 305 in the back. if you get the right offset rubbing shoudl be very minimal if any, specially if you go 19s.
and the lip, high disk in the front and you probably have around 2" lip usually, and for the rear, if you can really find a wheel, you can get up to around 4" lip
