sc3 brakes
Old 04-28-04, 06:05 PM
nysupraman
nysupraman's Avatar
Default sc3 brakes
i think my pads are worn, there are vibrations coming from the vehicle when i brake, and i think its worsening. anyways i know a mechanic that can do the fix for me but i need to know wut to buy? do i only need new pads, or more? also where can i buy them online?
Old 04-28-04, 07:27 PM
/Aerostar\
/Aerostar\'s Avatar
do em yourself!! its fun! Heres my tutorial which I recently wrote up: https://www.clublexus.com/forums/sho...hreadid=117244
I just bought pads cause I needed a quick fix, but if you want a thourough job, you should purchase the following:
Brake pads - $10 - 90 per axle
Shim kit - $50?
Brake lube - $1 per axle
Rotors turned (if needed) - $5/rotor
Brake fluid - $5
Good luck
PS. I used the cheap autozone brake pads and had absolutely no problems with them so far
Old 04-28-04, 08:05 PM
nysupraman
nysupraman's Avatar
thanks alot i guess the pads ell do. i found two fronts for 42 and two rears online for 50, i'll pass for autozone, nice tutorial!
Old 04-29-04, 01:15 AM
rominl
exclusive matchup
rominl's Avatar
well you need new pads probably. but at the same time i wonder if your rotors are warpped too
Infamous3
07-29-21 08:18 PM
mikek753
06-27-19 10:33 AM
lexrally
RX - 1st Gen (1999-2003)
13
07-15-15 01:18 PM
Glashub
07-03-15 02:47 PM
ByoungWoo
Suspension and Brakes
10-22-08 09:48 PM
Quick Reply: sc3 brakes
